# 24v heat bed
**URL:** <https://forum.lulzbot.com/t/24v-heat-bed/2764>\
**Created:** [January 11, 2016, 5:52pm UTC](https://forum.lulzbot.com/t/24v-heat-bed/2764 "2016-01-11T17:52:45Z")\
**Posts on this page:** 4\
**Author:** ![BloodyCactus](https://sea2.discourse-cdn.com/flex020/user_avatar/forum.lulzbot.com/bloodycactus/32/15_2.png) [@BloodyCactus](https://forum.lulzbot.com/u/BloodyCactus)\
**Post date:** [January 11, 2016, 5:52pm UTC](https://forum.lulzbot.com/t/24v-heat-bed/2764/1 "2016-01-11T17:52:45Z")
I want to upgrade my TAZ2 to a TAZ3 at least… the biggest thing I remember was going from a 12v to 24v heat bed + psu.
the 24v heat bed is not in stock on the store, I emailed support, who have never bothered to email back ([support@lulzbot.com](mailto:support@lulzbot.com)) (thats some awesome customer support right there), trying to find out when/if it would be back in stock… nada.
anyone know of any other compatible 24v heat beds of the same size I could use?
**Post date:** [January 11, 2016, 7:51pm UTC](https://forum.lulzbot.com/t/24v-heat-bed/2764/2 "2016-01-11T19:51:19Z")
You should probably check your spam filters. Them not writing back is unusual. They do have the fully assembled with a PEI sheet beds in stock in 24v. [https://www.lulzbot.com/store/parts/lulzbot-taz-heat-bed-kit](https://www.lulzbot.com/store/parts/lulzbot-taz-heat-bed-kit)
Here is the 12v to 24v upgrade proceedure:
[https://ohai.lulzbot.com/project/taz\_12v\_to\_24v/accessories/](https://ohai.lulzbot.com/project/taz_12v_to_24v/accessories/)
Edit: there is also the refurbished assembly option:
[http://i-t-w.com/parts/taz-5-4-3-24v-hotbed-with-heater-and-glass](http://i-t-w.com/parts/taz-5-4-3-24v-hotbed-with-heater-and-glass)
You can also get the metal Y endplates and other parts there
**Post date:** [January 11, 2016, 11:41pm UTC](https://forum.lulzbot.com/t/24v-heat-bed/2764/3 "2016-01-11T23:41:35Z")
I ended up getting the old style 24v heat bed from itw rather than the taz5 style one. need to figure ou t what else to upgrade to get to a taz3… slowly getting there! 🙂
**Post date:** [January 12, 2016, 12:56am UTC](https://forum.lulzbot.com/t/24v-heat-bed/2764/4 "2016-01-12T00:56:50Z")
The threaded rod setup is different, but I think it still uses the same rods. Don’t go with the Taz 3 bed mounts, Print the Taz 5 ones, they don’t have the lifting issue and will fit fine. The Taz 5 X carriage is also going to be a drop in replacement with some additional nice features. The X end springs went through a bunch of revisions.Ideally you want to order a set of the X end plates from Either ITW if they get them back in stock, Or Techsavvy34 here in the forums, then pick up a pair of the leadscrews and leadscrew nuts (do a search for Mitsumi in the forums for the exact part numbers) and go straight to Taz 4 or 5 spec. The jump from 3 to for is a huge quality upgrade, and requires reprinting the same amount of parts. Assuming you have to buy them all new, thats around $120 + plastic for a much better printing printer
Edit: also, check your power supply. The Taz 1 was the 12 volt version, the Taz 2 should be 24 volt already.
