# 3d printer settings help?
**URL:** <https://forum.lulzbot.com/t/3d-printer-settings-help/4355>\
**Category:** Software\
**Created:** [December 21, 2016, 12:21pm UTC](https://forum.lulzbot.com/t/3d-printer-settings-help/4355 "2016-12-21T12:21:33Z")\
**Posts on this page:** 4\
**Author:** ![trollioli](https://avatars.discourse-cdn.com/v4/letter/t/8dc957/32.png) [@trollioli](https://forum.lulzbot.com/u/trollioli)\
**Post date:** [December 21, 2016, 12:21pm UTC](https://forum.lulzbot.com/t/3d-printer-settings-help/4355/1 "2016-12-21T12:21:33Z")
First let me start out by saying I’m pretty new to this whole 3d printing thing and any help would be very much appreciated. Shortly after I purchased the Lulzbot mini, I found a kickstarter that allowed me to print out dungeon tiles for my Dungeons and Dragons game. I won’t put the link up because I don’t want to seem like I’m advertising, but the settings they suggest don’t seem to be in the lulzbot mini settings in Cura. What I mean is this:
## Recommended Print Settings for the Tiles
Temperate: PLA 200 (75 bed); ABS 220 (75 bed)
Primary Layer height: 0.1000
Top Solid Layers: 6
Bottom Solid Layers: 4
Outline Shells: 2
Infill: 15%
Speed: 60.0 mm/s
I assume the primary layer height is the layer height setting under the quality setting. But the top and bottom solid layers? Are they the bottom/top thickness under the fill setting? Also is outline shells the shell thickness setting under quality. I get the infill percentage and speed that’s a given. I set everything up to how I “thought” it was supposed to be and a simple 3x3 tile with 3 walls and one open space was going to take a whopping 13 hours! That can’t be right can it?
Again, thank you for your time.
**Author:** ![dmds](https://avatars.discourse-cdn.com/v4/letter/d/5f8ce5/32.png) [@dmds](https://forum.lulzbot.com/u/dmds)\
**Post date:** [December 21, 2016, 11:55pm UTC](https://forum.lulzbot.com/t/3d-printer-settings-help/4355/2 "2016-12-21T23:55:22Z")
Re: layer height: yes, you are correct.
Re: top/bottom solid layers: yes, this refers to the top/bottom thickness in Cura. However Cura has just 1 setting instead of 2 separate ones. So you could try setting it like this:
Bottom/Top Thickness: 0.6mm will give you 6 layers on both (because the layer height is 0.1mm per above.)
Bottom/Top Thickness: 0.4mm will give you 4 layers on both (again because the layer height is 0.1mm.)
Or you could try 0.5mm to compromise between the 2 suggested values they provided.
Or you could try 0.3mm to try to speed it up. I’m not sure how strong the part needs to be.
Re: outline shells: 2: For this, assuming 0.5mm nozzle, you should set the “shell thickness” parameter to 1 mm. (If you entered 2mm here, then you would get 4 shells, again assuming 0.5mm nozzle. This would make the outer shell take twice a long.)
This explanation of how the parameters relate is available in Cura if you hover the mouse over the field name and read the tool tip. (I learned a lot from Cura this way and then experimenting and watching the printer.)
FWIW, I usually set bed at 60 for PLA on my TAZ.
Hope this helps or someone can correct my mistakes. I’ve been printing only a few months.
**Post date:** [December 22, 2016, 4:51am UTC](https://forum.lulzbot.com/t/3d-printer-settings-help/4355/3 "2016-12-22T04:51:13Z")
Ahhh awesome. Yes, this helps out a lot. I will play with the settings a bit to see how long it takes. I appreciate the clarification more than you know.
**Author:** ![robajohn](https://avatars.discourse-cdn.com/v4/letter/r/5f9b8f/32.png) [@robajohn](https://forum.lulzbot.com/u/robajohn)\
**Post date:** [December 22, 2016, 9:16pm UTC](https://forum.lulzbot.com/t/3d-printer-settings-help/4355/4 "2016-12-22T21:16:14Z")
> [@dmds](#):
Concur! I think 75 is too hot for PLA. I always use 60 as well.
