# ABS filament feed problem
**URL:** <https://forum.lulzbot.com/t/abs-filament-feed-problem/6372>\
**Category:** LulzBot Mini\
**Created:** [December 17, 2018, 6:24am UTC](https://forum.lulzbot.com/t/abs-filament-feed-problem/6372 "2018-12-17T06:24:16Z")\
**Posts on this page:** 3\
**Author:** ![zizumara](https://avatars.discourse-cdn.com/v4/letter/z/a9adbd/32.png) [@zizumara](https://forum.lulzbot.com/u/zizumara)\
**Post date:** [December 17, 2018, 6:24am UTC](https://forum.lulzbot.com/t/abs-filament-feed-problem/6372/1 "2018-12-17T06:24:16Z")
I have had my Lulzbot Mini for a couple of weeks now and have been printing almost every day with ABS filament. Today it stopped in the middle of a 2 hour print. A test extrusion failed to extrude filament. Removing the filament revealed that the filament had a gouge in it made by the hobbed bolt. I cleaned the hobbed bolt and the print nozzle and tried again several times to get the filament to feed, getting the same results – the hobbed bolt would gouge the filament and stop feeding.
I noted that a few other posts noted problems like this with two possibilities: heat creep and idler screw adjustment. I ruled out heat creep because that is supposedly a problem with PLA only and the worn part of the filament wasn’t warm whenever I removed it. Another post stated that the separation between the washers on the idler screws should be about 5 mm. Though the distance appeared to be about 5 mm, I tightened them to be a little less than 5 mm and this seems to have cured the problem for now.
I thought I would share this information in case anyone out there sees the same problem and, heaven forbid, if my feed problems should return.
**Author:** ![Ehoff](https://avatars.discourse-cdn.com/v4/letter/e/3ab097/32.png) [@Ehoff](https://forum.lulzbot.com/u/Ehoff)\
**Post date:** [December 20, 2018, 3:00pm UTC](https://forum.lulzbot.com/t/abs-filament-feed-problem/6372/2 "2018-12-20T15:00:10Z")
Sometimes over tightening the thumbscrews can cause the toolhead to strip out the filament like you are describing. If the problem returns, try loosening them up just a little bit.
**Author:** ![edsunder](https://avatars.discourse-cdn.com/v4/letter/e/0ea827/32.png) [@edsunder](https://forum.lulzbot.com/u/edsunder)\
**Post date:** [December 20, 2018, 4:53pm UTC](https://forum.lulzbot.com/t/abs-filament-feed-problem/6372/3 "2018-12-20T16:53:42Z")
The other thing that I’ve noticed is that sometimes the way a particular print is done, there is so much fast extrusion, retraction, extrusion, retraction quickly that it will cause that wear. I’ve found that by either slowing things down a little bit or by changing the retraction distance, I can normally make that go away. This is the type of thing you’ll sort of figure out over time.
