This is my attempt at meeting the following requirements to improve ABS output:
- Very low cost
- Very light weight materials and heat rated 110C+
- 60C+ air temp
- Keep steppers, extruder, rambo and filament within suggested operating temp
- Easily removable
- Print duration less than 7 hours
As a result, I built an expandable type of pizza box that really just isolates the build area from everything else. I designed it around the constraints of the TAZ itself with minimal intrusion on the platform. If anyone is interested I will post results after some testing. The topper weight a little more than a Nema 17 in hand - less than 16oz. Either with the ceramic space heater or the built in bed it will maintain 70C.
