After installing Meteor 1.75 misses the wiper
I changed out the toolhead updated software, chose Meteor 1.75 in Marvin LCD panel.Set up correct toolhead in Cura. Now it wipes nozzle just behind the pad. HELP
Update. Used gcode to move it to correct wipe position. BUT now it will sometimes it wipes then double tap the bed washers then on 3rd washer it presses down hard then goes back to wiping but wipes behind the pad holder.
If leveling fails, it uses a hard-coded fail script in the firmware that isn’t affected by the GCODE.
Since a gcode fix hasn’t worked I did a hardware fix. I downloaded from Lulzbot the mini 2 wiper mount. Edit it, making the screw holes slots for adjusting. printed it by removing old mount and cleaning the nozzle manually. Mounted new one. It now wipes dead center every time!! Have started a print 5 times then stopped just to test then printed a few things on my to do list. Case closed!!
