Good afternoon~all,
Thank you first for taking time to read my post,I would like to ask you some suggestions about the chip–BQ76PL536.
I want to use BQ76PL536(this is the datasheet of BQ76PL536 : http://www.kynix.com/uploadfiles/pdf/BQ76PL536APAPT.pdf ) to be battery management and I have started using TS1 and then the corresponding flag bit was set. The temperature also drop down with that. Then I tried to clear the overheating flags and wrote one in TS1 of register–“ALERT_STATUS”, Next I wrote zero following on. But the overheating flags can’t still be cleared. How to solve it? The following contents is the process I tried to clear overheating flags.
ReadMessage(DEV_A,ADD_DEVICE_STATUS); //¶Ádevice_status״̬
value_dev5=readbuf[3]; //´æÈëvalue_dev£¬¾Ö²¿±äÁ¿
value_dev5 |= 0x20;
chip.DEVICE_STATUS=value_dev5;
SendMessage(DEV_A,ADD_DEVICE_STATUS); //д1
value_dev5 &= 0xDF;
SendMessage(DEV_A,ADD_DEVICE_STATUS); //д0
//2.¶Ôalert_status¼Ä´æÆ÷²Ù×÷
ReadMessage(DEV_A,ADD_ALERT_STATUS); //¶Áalert_status״̬
chip.ALERT_STATUS=value_dev5;
SendMessage(DEV_A,ADD_ALERT_STATUS); //½ÓÊÕµ½µÄÖµ£¬Ôٴη¢Ë͸øalert_status¼Ä´æÆ÷
chip.ALERT_STATUS &= 0x00;
SendMessage(DEV_A,ADD_ALERT_STATUS); //д0£¬·¢Ë͸øalert_status¼Ä´æÆ÷
Have you met such problems? Your help will be appreciated.
