I just got my taz 6. When I printed the two versions of the rocktopus the print head would touch all four corners of the bed to adjust the leveling. Now when I print, including another rocktopus, the unit does not go through the auto leveling procedure. What is the problem?
Sounds like you are not using a material profile. You might be in expert mode and you need to revert back to quick-print mode which will load and use the correct material profile for your print.
That may have been what happened. I will check settings and try again. Thanks for responding to my post. I will let you know what happens.
It worked! How simple and elegant the solution. Thank you so much for replying to my post and solving my problem.
