I seem to have all kinds of trouble keeping the bed alignmet stable on my 101
I guess first I should ask what sort of alignment I should expect.
I put a indicator on the x carriage and from corner to corner (as far out to a corner as I can get with the indicator mounted) about the best I can do is +/- .02mm. And if I move the Z up and down, then measure the corners again, more often than not it’s somewhat different. Sometimes +/- .05mm different.
Am I chasing too much accuracy?
I’ve modified the z nuts to minimize backlash (that’s what started this adventure…I modified the z axis for spring loaded nuts and ball slides. the first install of those parts was so bad I backed them all out and restored all the origina parts.)
But at this point only the modded Z nuts are not original. So, I get it all aligned then heat it up and start a print and a signifcant part of the skirt does not adhere to the platform.
The same gcode file will work fine one day, then not the next.
…a bit frustrated at the moment.
