# Calibration Cube Taz6
**URL:** <https://forum.lulzbot.com/t/calibration-cube-taz6/6342>\
**Created:** [December 3, 2018, 4:02pm UTC](https://forum.lulzbot.com/t/calibration-cube-taz6/6342 "2018-12-03T16:02:30Z")\
**Posts on this page:** 6\
**Author:** ![OyarzoPablo](https://avatars.discourse-cdn.com/v4/letter/o/977dab/32.png) [@OyarzoPablo](https://forum.lulzbot.com/u/OyarzoPablo)\
**Post date:** [December 3, 2018, 4:02pm UTC](https://forum.lulzbot.com/t/calibration-cube-taz6/6342/1 "2018-12-03T16:02:30Z")
Printed the calibration cube of Thingiverse: [https://www.thingiverse.com/thing:1278865](https://www.thingiverse.com/thing:1278865)
From 20x20x20 mm
I got
X = 19.90
Y = 20.15
Z = 19.80
How do I proced to take these values closer to 20mm?
**Author:** ![Keebie81](https://avatars.discourse-cdn.com/v4/letter/k/858c86/32.png) [@Keebie81](https://forum.lulzbot.com/u/Keebie81)\
**Post date:** [December 3, 2018, 5:23pm UTC](https://forum.lulzbot.com/t/calibration-cube-taz6/6342/2 "2018-12-03T17:23:41Z")
You adjust the steps/mm, but for that small variance I wouldnt worry. 3d printing isnt going to get an exact measurement due to material shrinkage and such.
**Post date:** [December 3, 2018, 5:54pm UTC](https://forum.lulzbot.com/t/calibration-cube-taz6/6342/3 "2018-12-03T17:54:35Z")
In Cura or Setting on the Lulzbot?
I wanna get as close as I can, as I’ve seen many examples prints on the Lulzbot, Ender and Prusa.
**Author:** ![zachah](https://avatars.discourse-cdn.com/v4/letter/z/919ad9/32.png) [@zachah](https://forum.lulzbot.com/u/zachah)\
**Post date:** [December 3, 2018, 9:54pm UTC](https://forum.lulzbot.com/t/calibration-cube-taz6/6342/4 "2018-12-03T21:54:15Z")
The easiest way is going to be with Cura. Use the scale option and un-check Uniform Scaling.
Then do some cross multiplying to find our desired X Y and Y percentages values. In this case with your measurements that comes out to:
X 100.50%
Y 99.26%
Z 101.01%
You’ll take your desired value (20) and multiply that by 100 (for 100 percent), then you’ll divide by your measured value(X,Y,Z) to get your adjusted percentage.
20\*100=2000
2000/19.90=100.502512563
2000/20.15=99.255583127
2000/19.80=101.01010101
**Post date:** [December 6, 2018, 2:46pm UTC](https://forum.lulzbot.com/t/calibration-cube-taz6/6342/5 "2018-12-06T14:46:02Z")
@zachah Worked great!
NOTE: if you do the test, be sure to rotate the model to match x and y axis. had problems for that.
1. Is there a way to make it permanent? on the setting for any imported STL?
2. What was the other not simpler way?
**Post date:** [December 8, 2018, 4:16am UTC](https://forum.lulzbot.com/t/calibration-cube-taz6/6342/6 "2018-12-08T04:16:32Z")
I’m not aware of a way to have Cura automatically do this when importing an stl.
The less simple way would be to adjust your X,Y, and Z steps/mm. The issue with this is that it can affect your auto-leveling if adjusted too much since the corner positions are more or less hard coded into the firmware.
