# Cura 20 Pause at Layer plugin
**URL:** <https://forum.lulzbot.com/t/cura-20-pause-at-layer-plugin/4028>\
**Category:** Software\
**Created:** [September 25, 2016, 5:38pm UTC](https://forum.lulzbot.com/t/cura-20-pause-at-layer-plugin/4028 "2016-09-25T17:38:00Z")\
**Posts on this page:** 2\
**Author:** ![mrvanes](https://sea2.discourse-cdn.com/flex020/user_avatar/forum.lulzbot.com/mrvanes/32/103_2.png) [@mrvanes](https://forum.lulzbot.com/u/mrvanes)\
**Post date:** [September 25, 2016, 5:38pm UTC](https://forum.lulzbot.com/t/cura-20-pause-at-layer-plugin/4028/1 "2016-09-25T17:38:00Z")
Hi,
I just started to experiment with 3D printing on my brand new Mini and wanted to know if multi-color printing with a manual filament change was feasable. I found the Pause at height plugin in Cura, but although it worked somewhat, I started hacking up my personal version to cater for my needs.
Maybe it’s of use to anyone, so I thought I’d share it with the community.
Changes from Pause at height:
- Pause before Cura Layer number instead of Z height mm.
- Insert Layer comment after pause, this solves some glitches with gcode viewers (e.g. octoprint)
- Set resume layer speed factor, might improve adhesion after filament change
- Set resume layer extrusion factor for new layer, same reason
- Set resume layer fan speed, same reason (100% is profile max fan speed)
(Any resume layer factor change is valid for the entire layer and gets reset for the next one)
- Fix absolute extrusion problems (unwanted retracts) when extruding during pause
Known problems:
- A lot of (commented) debug statements lying around the code
- Not tested for one at a time prints!
- Cura renders 1st layer after pause extremely bad, but it doesn’t affect print quality.
- I’m not planning on supporting this code, just sharing it as is
Download, unzip, save in ~/.cura/plugins and enjoy.
[pauseAtL.zip](https://forum.lulzbot.com/uploads/short-url/n3J5A3WzIweIqjpBPYJKkPM0mVc.zip) (2.38 KB)
**Post date:** [August 17, 2017, 9:29pm UTC](https://forum.lulzbot.com/t/cura-20-pause-at-layer-plugin/4028/2 "2017-08-17T21:29:04Z")
Thanks! Exactly what I was looking for. The Lulzbot folks should include this as part of their Cura Lulzbot Edition (and support it).
Now would be a good time to add it to the Cura 2 beta.
