I usually don’t use a raft, but this particular print needs one (thin/flat with a lot of fine details). Unfortunately Cura outputs gcode for the raft using the fine profile, so it takes longer to print the raft than the objects. Anyone know if there’s a way to make Cura print the raft faster (i.e. using a fast or medium profile), but then use the fine profile for the actual print?
