Hey TAZ land! Any advice out there forDremmeling PLA? I’ve had mixed success. Demmel heads just heat the stuff up so fast!!! Thanks!
You definitely need a variable speed Dremel tool, running as slowly as possible. You need to be patient and remove material very slowly. It depends on exactly what you’re trying to achieve, but a coarse metal bit has worked OK for me.
For PLA especially, if I can possibly do the work with a file or craft knife, I use that for manual removal and just use the Dremel when it’s difficult to do it any other way.
