# E1:Err: MINTEMP TAZ6 Dual Head V2
**URL:** <https://forum.lulzbot.com/t/e1-mintemp-taz6-dual-head-v2/6694>\
**Created:** [May 9, 2019, 6:52am UTC](https://forum.lulzbot.com/t/e1-mintemp-taz6-dual-head-v2/6694 "2019-05-09T06:52:45Z")\
**Posts on this page:** 3\
**Author:** ![field3d](https://avatars.discourse-cdn.com/v4/letter/f/6de8d8/32.png) [@field3d](https://forum.lulzbot.com/u/field3d)\
**Post date:** [May 9, 2019, 6:52am UTC](https://forum.lulzbot.com/t/e1-mintemp-taz6-dual-head-v2/6694/1 "2019-05-09T06:52:45Z")
Hello. I received an used TAZ 6 and since the beginning it showed errors as power lost and that there is a new firmware when I tried to print. When I tried to print it said printing and then after 3 minutes around it came the power lost error. Never reached the first extruder the 23% in the LCD display with a fan icon. Then it resets. I could never print. Then because I that, I updated the firmware automatically from the software cure and after that in the display of the TAZ 6 I see this error:
```nohighlight
E1:Err: MINTEMP
And the reset text. Now is impossible to access because is stuck in the error. The printer has installed a dual extruder head V2. What could be the problem?
**Post date:** [May 9, 2019, 1:26pm UTC](https://forum.lulzbot.com/t/e1-mintemp-taz6-dual-head-v2/6694/2 "2019-05-09T13:26:13Z")
E1 Err Min Temp is a thermistor error on the left-hand side extruder (E1). It suggests that something along that wiring path has an intermittent break. Reach out to the support team at [https://LulzBot.com/Support](https://LulzBot.com/Support) and they’ll be able to help you determine where the break is. If you have access to a multi-meter it’ll help make diagnosis and confirmation quick.
**Post date:** [May 9, 2019, 7:49pm UTC](https://forum.lulzbot.com/t/e1-mintemp-taz6-dual-head-v2/6694/3 "2019-05-09T19:49:15Z")
Thank you is working now. It had a connector inside the rambo disconnected. I don’t know why happened this but i plugged and ready.
