I am having a strange problem with the extruder drive. When I print at 80mm per second or higher on a large part, the filament strips out on the hobbed bolt. This always happens after the first slow layer when the speed comes up to normal on long infill runs. If I change the build speed to 60mm per second, it will print all day.
Has anyone experienced this? Could the acceleration or jerk be set to high on the extruder?
Make sure the washer is on the outside of the hobbed bolt bearing as indicated in the picture, between the nut and bearing.
I have had sharp clicking noises coming from my extruder assembly since it was new. I recently had filament stripping problems when I would try to print a large part at high speed. I noticed the washer was misplaced after browsing the KITTAZ setup documents. The washer was installed on the filament side of that outer bearing. I am currently printing the large part I had problems with, without issue. And the clicks are gone.
