Firmware Question Taz 4
I have a quick question regarding the default firmware for the Taz 4.
I noticed that on the Q3 firmware the default firmware has the following lines of code:
#define HOMING_FEEDRATE {50*60, 50*60, 8*60, 0}  // set the homing speeds (mm/min)
// default settings
#define DEFAULT_AXIS_STEPS_PER_UNIT   {100.5,100.5,1600,866}  // default steps per unit for TAZ {X,Y,Z,E}
#define DEFAULT_E1_STEPS_PER_UNIT     800                    // default steps per unit for second extruder (800)
#define DEFAULT_MAX_FEEDRATE          {800, 800, 8, 50}      // (mm/sec)
#define DEFAULT_MAX_ACCELERATION      {9000,9000,100,10000}  // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for skeinforge 40+, for older versions raise them a lot.
My questions are:
HOMING_FEEDRATE
I have seen some users lower the Z homing_feedrate values from what is indicated. For example i’ve seen 480 & 380 from some…
Does this help prevent the printer from missing steps while performing Z homing? I have noticed that occasionally the Z Axis will stall but only while homing. All other print moves seem to function normally.
For this the defaults of {100.5,100.5,1600,866} do not match the values printed on my acceptance record (Specifically the Z value. I understand the variance for the E value. The acceptance record uses a value of 400 for Z vice the indicated 1600. When 400 is placed there the Z axis does not move correct distances. For example when commanding it to move 100mm it only moves ~20ish? what value plays a factor for this offset? With 1600 written to firmware it appears to move correct distances to the best of my measurement capabilities, but why?
Lastly what is considered an accelerated start movement? this value seems consistent across multiple users but I do not fully understand what it means.
Slowing down the Z axis homing rate can help ensure smooth movement.
We increased the microstepping amount and thus had to increase the steps per unit to compensate in a later version of the firmware.
I can only assume that it is the absolute maximum amount of acceleration that could occur. I’m assuming that it is in mm/s^2 but it could be in mm/min^2 but that seems slow. These don’t really matter too much to the average user. what you should be concerned with are–as you mentioned–extruder steps and the acceleration that is set a couple of lines further down. The default value is 500.
