Hi,
Is it possible to print from an SD card using the FlexyDually v2 toolhead? Or does your computer need to be plugged in the entire time?
Hi,
Yes, you print from your SD card just as you would with the single extruder.
You may want to plug in your machine to extrude some filament from each toolhead before the print.
Yes
And computer need pluging in
Alternative to keeping the computer plugged into the USB port, use a skirt to prime single or dual nozzles.
Ooze shield is always good to turn on in slicer and acts to prime the extruder also.
