My flexystruder cracked and Lulzbot tells me it’s out of warranty… they gave me the STL but didn’t give me any print settings with it…
I can find the gcode for v1 but this is a version 2, can anyone tell me how to slice this thing?
Print it in abs, 85% infil or better, just on the bed as usual, no support. I would recommend using brim.
Layer thickness?
Any problem with 100%?
Depends on your nozzle, for a .5mm nozzle .40 for start, .35 for subsequent layers, or less if you want more detail.
100% should be fine if you are well dialed in and not overextruding at all. If it looks like melty warped soup after you print it you were probably overextruding.
Thanks… I really wish they sold the replacement part… feeling like I spent $300 so I’d have support if something went wrong and… yea… here I am using the very helpful community.
There’s always the other one too!
www.thingiverse.com/thing:1201229
The next fun part is when you find out you need to order some drill bits to install the ptfe tube.
