Help with Green ABS
I am struggling to print a part in Green ABS (see attached).
Hot end = 230 deg. Bed = 110 deg. Full enclosure controlled at 35 deg. I have measured filament diameter and changed settings accordingly.
ANy ideas?
Try 240 or 245 for temp.
I was going to say 245 minimum and no fan. The defaults in Cura should work If they have not been changed from the download.
OK, I’m an idiot.
I added a second fan to my Taz and at 100% the fans were cooling the head down to 180 degrees.
I have now set fan max to 50% and it’s printing OK.
Thank’s for your response.
J
ABS almost never needs any cooling. Cooling it actually makes lifting and layer seperation worse. You only want to have any cooling with ABS when you are printing a bridge, or when you are printing a very small part section. Otherwise it will generally harm the print.
