# Hot end heating problem
**URL:** <https://forum.lulzbot.com/t/hot-end-heating-problem/258>\
**Category:** AO-101 & AO-100\
**Created:** [September 3, 2013, 5:05pm UTC](https://forum.lulzbot.com/t/hot-end-heating-problem/258 "2013-09-03T17:05:20Z")\
**Posts on this page:** 14\
**Author:** ![QuantumVenom](https://avatars.discourse-cdn.com/v4/letter/q/85f322/32.png) [@QuantumVenom](https://forum.lulzbot.com/u/QuantumVenom)\
**Post date:** [September 3, 2013, 5:05pm UTC](https://forum.lulzbot.com/t/hot-end-heating-problem/258/1 "2013-09-03T17:05:20Z")
I am having a problem with the hot end. I turned the printer on this morning, loaded my file, then set the nozzle and bed temp then hit set. The nozzle reached about 175 (my target was 185), then all of a sudden it just shut off and the temperature started to decrease. I haven’t been able to get it to start heating again. Did something short circuit or do I need to replace the thermistor (I hope not). I’ve checked all the connections I can without removing the hot end setup.
Any ideas?
Thanks
**Author:** ![gannon](https://sea2.discourse-cdn.com/flex020/user_avatar/forum.lulzbot.com/gannon/32/10_2.png) [@gannon](https://forum.lulzbot.com/u/gannon)\
**Post date:** [September 3, 2013, 8:33pm UTC](https://forum.lulzbot.com/t/hot-end-heating-problem/258/2 "2013-09-03T20:33:19Z")
Do you get any errors reported? Can you move any of the axes?
I can only think of 3 main parts that could cause this issue. Wiring being the most common I have dealt with.
1. Thermistor issue (Wiring issue, damaged thermistor)
2. Heater issue (Wiring issue, damaged resistor / heater cartridge)
3. Power issue (PSU failure, blown FET)
**Post date:** [September 3, 2013, 8:42pm UTC](https://forum.lulzbot.com/t/hot-end-heating-problem/258/3 "2013-09-03T20:42:47Z")
I would recommend powering down the printer, then disconnect the hot end from the wiring harness. Test the hot end for the proper resistance- the smaller orange wires are for the thermistor and should read ~100k at room temperature. The larger red wires are connected to the heater resistor and should read between ~4-7 Ohm. Reconnect the hot end wiring to the wiring harness. Make sure that the pins are fully seated within the connector housing and if everything tests out bring the printer back up to extrusion temperature. You can test the hot end heater resistor when it’s attempting to heat, by checking the two contact points on the red wiring through the connector. Make sure you do not short anything to to orange connectors/wiring.
**Post date:** [September 3, 2013, 8:54pm UTC](https://forum.lulzbot.com/t/hot-end-heating-problem/258/4 "2013-09-03T20:54:44Z")
Thanks for the replies. I don’t get any errors and I can still move all three axes. PrintRun is still reading the temperature correctly so I think it is something with the resistor, but I’ll be checking both the thermisor and resistor tomorrow when I have a chance.
Thanks again.
**Post date:** [September 4, 2013, 4:22pm UTC](https://forum.lulzbot.com/t/hot-end-heating-problem/258/5 "2013-09-04T16:22:32Z")
I’ve tested the thermistor and resistor both while turned off and while trying to heat. Nothing seems to be wrong, the correct resistance is there. I’m not sure what to do…
**Post date:** [September 4, 2013, 4:38pm UTC](https://forum.lulzbot.com/t/hot-end-heating-problem/258/6 "2013-09-04T16:38:34Z")
What is the voltage across the heater terminals on the board supposed to be. I’m only getting about 4.5 mV and I’m not reading any current. Something seems a little off there.
**Post date:** [September 4, 2013, 4:45pm UTC](https://forum.lulzbot.com/t/hot-end-heating-problem/258/7 "2013-09-04T16:45:26Z")
Should be 12V coming from the electronics.
**Post date:** [September 4, 2013, 4:49pm UTC](https://forum.lulzbot.com/t/hot-end-heating-problem/258/8 "2013-09-04T16:49:53Z")
Does that mean the power supply is messed up? I just checked the back of the board and it doesn’t look like anything is fried.
**Post date:** [September 4, 2013, 7:55pm UTC](https://forum.lulzbot.com/t/hot-end-heating-problem/258/9 "2013-09-04T19:55:39Z")
There are two fuses you can check, on the right hand side of the board in this image: [http://reprap.org/mediawiki/images/5/5c/Rambo-conn-all.jpg](http://reprap.org/mediawiki/images/5/5c/Rambo-conn-all.jpg) Is the hot end thermistor connected to T0 when you are testing? It should be able to read the ambient temperature. If it’s reading correctly, is it still reading the same when you rest the voltage at Extruder 0 Heat? If so, please email us at [support@lulzbot.com](mailto:support@lulzbot.com) and we can figure out what needs to happen.
**Post date:** [September 5, 2013, 2:53pm UTC](https://forum.lulzbot.com/t/hot-end-heating-problem/258/10 "2013-09-05T14:53:05Z")
I’ve determined it’s a problem with the main connection between the board and the nozzle. I was playing with that connection while it was trying to heat and I noticed a few things. 1, the connection itself became somewhat hot and 2, depending on how the connection was moved, it would either be heating or it wouldn’t be. I disconnected it and noticed there was some heat damage on the board side of the connection. I attached a picture showing the damage. What would cause this?
Thanks,
Chris
 ![Heat damage.JPG](https://us1.discourse-cdn.com/flex020/uploads/lulzbot/original/1X/6d324d22f6e568a158a2fad7131e6d88b14cfa0e.jpeg)
**Post date:** [September 5, 2013, 2:58pm UTC](https://forum.lulzbot.com/t/hot-end-heating-problem/258/11 "2013-09-05T14:58:34Z")
Well, it could have been heated by the current passing through the connector (IIRC those are rated fro 1-2 amps), or it could have been heated externally (from the hotend).
I’m not sure which, but unless the connector was really close to the hotend I would guess the former.
**Post date:** [September 5, 2013, 3:24pm UTC](https://forum.lulzbot.com/t/hot-end-heating-problem/258/12 "2013-09-05T15:24:16Z")
It can be caused by an intermittent connection and the tiny bit of arcing that will occur. The connectors and pins you need are:
Male connector pins, 24-30 AWG Digi-Key 16-02-0108
Female connector pins, 22-24 AWG Digi-Key 16-02-0102
CONN HOUSING MALE 4POS .100 Digi-Key 0701070003
CONN HOUSING 4POS .100 W/LATCH Digi-Key 0050579404
**Post date:** [September 5, 2013, 4:48pm UTC](https://forum.lulzbot.com/t/hot-end-heating-problem/258/13 "2013-09-05T16:48:15Z")
Thanks for the help everyone! I will be ordering new pins and housing. Hopefully this will fix the issue and allow me to have a more permanent connection.
Thanks again,
Chris
**Author:** ![kv1](https://avatars.discourse-cdn.com/v4/letter/k/3e96dc/32.png) [@kv1](https://forum.lulzbot.com/u/kv1)\
**Post date:** [April 10, 2015, 8:22am UTC](https://forum.lulzbot.com/t/hot-end-heating-problem/258/14 "2015-04-10T08:22:27Z")
please check out this thread, as it evolved into the main something does not heat up thread:
[https://forum.lulzbot.com/t/hotend-no-longer-heats-up/127/28](https://forum.lulzbot.com/t/hotend-no-longer-heats-up/127/28)
I posted an alternative to the green resistor here (same thread):
