I changed my TAZ 5 toolhead to a M175 what parameters do I need to change? Feed, retraction, filament size, etc. or can I change everything necessary by changing the printer model? I use Simplify 3D to create my G codes. Thank you
You need to change the firmware to the M175 firmware (Marlin_TAZ5_M175_2.0.0.144.1_ffaa466.hex). In Simplify 3D, you’ll need to make sure you set the filament diameter in your slicer. Feed, retraction and most other speeds should be fine.
Wrathernaut, thanks again, you saved the day!
