# importing .slt file from Rhino
**URL:** <https://forum.lulzbot.com/t/importing-slt-file-from-rhino/2387>\
**Category:** Software\
**Created:** [October 28, 2015, 6:35pm UTC](https://forum.lulzbot.com/t/importing-slt-file-from-rhino/2387 "2015-10-28T18:35:16Z")\
**Posts on this page:** 3\
**Author:** ![hamp3007](https://avatars.discourse-cdn.com/v4/letter/h/258eb7/32.png) [@hamp3007](https://forum.lulzbot.com/u/hamp3007)\
**Post date:** [October 28, 2015, 6:35pm UTC](https://forum.lulzbot.com/t/importing-slt-file-from-rhino/2387/1 "2015-10-28T18:35:16Z")
I have an object the I drew in Rhino 5. I saved it as a .slt file and imported it into Cura. However, the size is all wrong. How do you import it so that it keeps it’s size integrity?
Thanks,
Hamp Stevens
**Author:** ![nickthetait](https://avatars.discourse-cdn.com/v4/letter/n/ac8455/32.png) [@nickthetait](https://forum.lulzbot.com/u/nickthetait)\
**Post date:** [October 29, 2015, 1:25pm UTC](https://forum.lulzbot.com/t/importing-slt-file-from-rhino/2387/2 "2015-10-29T13:25:06Z")
Hi Hamp,
Cura uses milimeters as the default (and only) measurement unit. All you should need to do is export the model using mm, which is typically a preference/setting in most CAD packages. Please let us know if that works.
**Author:** ![gghouck](https://avatars.discourse-cdn.com/v4/letter/g/a88e4f/32.png) [@gghouck](https://forum.lulzbot.com/u/gghouck)\
**Post date:** [October 30, 2015, 11:35pm UTC](https://forum.lulzbot.com/t/importing-slt-file-from-rhino/2387/3 "2015-10-30T23:35:38Z")
I had the same issue, scaling up by a factor of 25.4 (converting inches to millimeters) was the cure. You can set up rhino to use a default template, and for that template to be in millimeters. IIRC Rhinos default metric template was too fine for printing, so I use one that graduated a millimeter into fourths.
