Isolation problem of input terminal
Isolation of the input terminal of the IR2110 chip
When the input end of the IR2110 chip is connected to other chips or circuits, that is, when the output end of the other circuit is connected to the input end of the IR2110 chip, when should an isolation device be added between the two? When is no need to isolate the device?
