Hi -
Have a new Taz mini - great machine. I am trying to print a larger object of about 6 x 3 x 3 inches. It will start and finish a print with no object in between - i.e. no warning no object was sent to the printer. The only indication nothing is going to be printed is there will be no progress bar under the Control icon.
I’ve trimmed my model to 5.8 inches or 147.32mm, which is less than stated volume of 152mm x 152mm x 158mm. Still, it won’t print (and there really is no warning). What is the actual max volume.
My STL’s are inch, so I scale to 25.4. I have noticed the any scale that produce an object above about 140 or 142mm is ignored. (I need a true 1:1 print, but I am using that to try to discover what is happening).
