# latest flexydualie files
**URL:** <https://forum.lulzbot.com/t/latest-flexydualie-files/872>\
**Created:** [October 2, 2014, 4:21am UTC](https://forum.lulzbot.com/t/latest-flexydualie-files/872 "2014-10-02T04:21:58Z")\
**Posts on this page:** 6\
**Author:** ![djohnson](https://sea2.discourse-cdn.com/flex020/user_avatar/forum.lulzbot.com/djohnson/32/9828_2.png) [@djohnson](https://forum.lulzbot.com/u/djohnson)\
**Post date:** [October 2, 2014, 4:21am UTC](https://forum.lulzbot.com/t/latest-flexydualie-files/872/1 "2014-10-02T04:21:58Z")
Hi, can someone point me to the latest FlexyDualie files/info?
I’m interested in building the dual extruder but my primary interest is with ninjaflex as the second filament.
Thanks,
**Post date:** [October 2, 2014, 3:21pm UTC](https://forum.lulzbot.com/t/latest-flexydualie-files/872/2 "2014-10-02T15:21:19Z")
[http://devel.lulzbot.com/TAZ/accessories/flexy-dualie/](http://devel.lulzbot.com/TAZ/accessories/flexy-dualie/)
**Post date:** [October 3, 2014, 4:25am UTC](https://forum.lulzbot.com/t/latest-flexydualie-files/872/3 "2014-10-03T04:25:28Z")
> [@jebba](#):
> [Index of /TAZ/accessories/flexy-dualie](http://devel.lulzbot.com/TAZ/accessories/flexy-dualie/)
I dont see any .stl or gcode files at that location. are those available somewhere?
**Post date:** [October 4, 2014, 8:42pm UTC](https://forum.lulzbot.com/t/latest-flexydualie-files/872/4 "2014-10-04T20:42:27Z")
> [@djohnson](#):
> > [@jebba](#):
Hmm, there are some in here, including the FreeCAD source, but I’m not sure if they are the latest. Also not sure why they are in the novelties directory:
[http://devel.lulzbot.com/TAZ/accessories/flexy-dualie/novelties/](http://devel.lulzbot.com/TAZ/accessories/flexy-dualie/novelties/)
I’ll see where the latest files are, if they aren’t those.
-Jeff
**Post date:** [October 5, 2014, 8:47pm UTC](https://forum.lulzbot.com/t/latest-flexydualie-files/872/5 "2014-10-05T20:47:50Z")
thanks Jeff,i’ll wait to hear for an update.
Most of the files I see n that folder appear to be test models.
**Author:** ![bam](https://avatars.discourse-cdn.com/v4/letter/b/34f0e0/32.png) [@bam](https://forum.lulzbot.com/u/bam)\
**Post date:** [October 6, 2014, 1:13pm UTC](https://forum.lulzbot.com/t/latest-flexydualie-files/872/6 "2014-10-06T13:13:43Z")
Heyo!
The FlexyDualie is identical to the standard dual extruder, but with a flexystruder body mounted in place of one of the 2 standard gregs wade extruders. It also comes standard with 0.5mm nozzles instead of the .35mm nozzles on the standard dual, this helps significantly with the ninjaflex printing speed.
To build a flexydualie you’ll need:
1x assembled flexystruder body (V1.1) [http://devel.lulzbot.com/TAZ/accessories/flexystruder/flexystruder-1.0/STL\_&\_G-code/flexystruder-V1.1.stl](http://devel.lulzbot.com/TAZ/accessories/flexystruder/flexystruder-1.0/STL_&_G-code/flexystruder-V1.1.stl)
1x assembled greg’s wade extruder (you can use the one from your standard toolhead or : [https://ohai-kit.alephobjects.com/project/4043e3e5-f907-4a9a-aa46-c2fb94e0c318/](https://ohai-kit.alephobjects.com/project/4043e3e5-f907-4a9a-aa46-c2fb94e0c318/) the stl files for these parts are located in the printed parts section of all of our TAZ devel directories
1x lower bracket V1.1 [http://devel.lulzbot.com/TAZ/accessories/dual\_extruder/dual\_extruder-1.0/stl-gcode/Lower\_Bracket/Lower\_Bracket-V1.1.stl](http://devel.lulzbot.com/TAZ/accessories/dual_extruder/dual_extruder-1.0/stl-gcode/Lower_Bracket/Lower_Bracket-V1.1.stl)
1x flex plate V0.9 [http://devel.lulzbot.com/TAZ/accessories/dual\_extruder/dual\_extruder-1.0/stl-gcode/Flex\_plate/Flex\_Plate-0.9.stl](http://devel.lulzbot.com/TAZ/accessories/dual_extruder/dual_extruder-1.0/stl-gcode/Flex_plate/Flex_Plate-0.9.stl)
1x dual extruder mount V1.3 [http://devel.lulzbot.com/TAZ/accessories/dual\_extruder/dual\_extruder-1.0/stl-gcode/Dual\_mount/Dual\_Extruder\_mt-1.3.stl](http://devel.lulzbot.com/TAZ/accessories/dual_extruder/dual_extruder-1.0/stl-gcode/Dual_mount/Dual_Extruder_mt-1.3.stl)
Assembly instructions for the dual are here, just instal the flexystruder body in place of the front greg’s wade extruder.
Happy printing!
-bam
