# Live Z Adjust
**URL:** <https://forum.lulzbot.com/t/live-z-adjust/6103>\
**Created:** [August 19, 2018, 11:20pm UTC](https://forum.lulzbot.com/t/live-z-adjust/6103 "2018-08-19T23:20:39Z")\
**Posts on this page:** 4\
**Author:** ![inventabuild](https://avatars.discourse-cdn.com/v4/letter/i/c89c15/32.png) [@inventabuild](https://forum.lulzbot.com/u/inventabuild)\
**Post date:** [August 19, 2018, 11:20pm UTC](https://forum.lulzbot.com/t/live-z-adjust/6103/1 "2018-08-19T23:20:39Z")
How do I do a live z adjust while my TAZ 4 is printing? I’m on Marlin from 2014.
The reason for my question is that If my hot end is too low or too high I need to move the hot end down or up to compensate.
**Post date:** [August 20, 2018, 2:39am UTC](https://forum.lulzbot.com/t/live-z-adjust/6103/2 "2018-08-20T02:39:49Z")
That is a Mini and Taz 6 function that is not in the Taz 4/5 firmware. They are manual height adjusted printers with the Thumb screw on the left side of the printer. Along with manually leveled heat bed adjustment.
**Post date:** [August 20, 2018, 2:53am UTC](https://forum.lulzbot.com/t/live-z-adjust/6103/3 "2018-08-20T02:53:45Z")
Thanks for the info. I upgraded my TAZ 4 hardware to TAZ 6 with the metal corner washers that get tapped to create the print plane, the thicker x-axis rods, anti-seize bushing on the z-axis, etc; however I did not upgrade the electronics box and I’m still running TAZ 4 dual extruder firmware because I was unable to get the TAZ 6 firmware to run properly on my setup.
I guess this is another reason to take another stab at getting the TAZ 6 firmware to work on my upgraded printer. I’m wondering if the electronics box also needs to be upgraded to run the TAZ 6 firmware properly or if it s/ work on the TAZ 4 electronics box / RAMBO board?
**Post date:** [August 20, 2018, 12:42pm UTC](https://forum.lulzbot.com/t/live-z-adjust/6103/4 "2018-08-20T12:42:55Z")
The old control box does not have enough pins/wires to run all the additional lines you need. The board can do it but you would have to run the extras through a hole drilled/cut in the case.
