Hi All!
Long story short, I started a test print with some new PLA filament and left it overnight to run. When I came back in the next day, one of the extruders on my Lulzbot Taz Pro Dual Extruder Toolhead had baked filament encasing
I wasn’t able to remove all the baked filament from the hot end extruder , as unfortunately it encases the entire extruder. Please see images below:
1016 & 1017 images are the clogged extruder from which I removed from the tool head. You can see not only does it encase the entire extruder, but the leveling board as well. 1018 shows the current status of the dual extruder tool head, which I was able to put back on the tool head plate, and successfully loaded filament through the 1st extruder which had no filament use, and was completely functional.
The attached video file 1019 shows what happens when I try and run a print from a USB. The printer starts to shake when the toolhead reaches the top of the Y axis, as if it something wrong with the Y axis calibration. If I manually pull the toolhead down, the printer is able to bring the toolhead back to the top of the Y axis pulley, indicating there is nothing physically wrong with being able to move up and down the Y axis. Once it starts to shake, the printer itself just restarts.
Let me know your thoughts and if there is any suggestions you may have. Ive already reached out to lulzbot to order a new dual extruder, since removing the clogged extruder does anyone think it is possible to print using the loadable extruder without interfering without running into calibration issues?
Note this is the dual extruder from the original shipped printer, not the new v3 tool head.
Thanks,
Starr Kramer, Victor
Visualization Technology Specialist
Contractor, Medical Science and Computing, Inc.
Bioinformatics and Computational Biosciences Branch (BCBB)
NIH/NIAID/OD/OSMO/OCICB
Phone Cell: 202-748-2878
