# Mini 2.0 Bed Not Level With X-Axis
**URL:** <https://forum.lulzbot.com/t/mini-2-0-bed-not-level-with-x-axis/23545>\
**Category:** LulzBot Mini\
**Created:** [July 26, 2021, 10:09pm UTC](https://forum.lulzbot.com/t/mini-2-0-bed-not-level-with-x-axis/23545 "2021-07-26T22:09:55Z")\
**Posts on this page:** 1\
**Showing post:** 2
**Author:** ![intelinc](https://avatars.discourse-cdn.com/v4/letter/i/b5a626/32.png) [@intelinc](https://forum.lulzbot.com/u/intelinc)\
**Post date:** [August 4, 2021, 12:15am UTC](https://forum.lulzbot.com/t/mini-2-0-bed-not-level-with-x-axis/23545/2 "2021-08-04T00:15:44Z")
While your bed may be tilted,] I wouldn’t use the x gantry as a means of determining this. Particularly on the 2, which can be unreliable even after tramming. You should measure the bed from the frame assemblies: the lower Z axis mounts are probably good for this, allowing you to run a straight edge from either side over the bed and then measure between that and the bed surface for example. Probably also a good idea to measure down to the metal frame surface as well and compare.
I would also make sure that the tramming/x levelling process on the 2 is accurately bringing the gantry level, and that the homing process _after_ tramming is not introducing a subsequent tilt. My Mini 2 had a little printed belt stay that held the looped end of the X axis belt on the left side. This part was sitting slightly more to the left than it was designed for, and would hit a recessed portion of the X motor mount and force the left side of the gantry down very slightly when the printer homed. Result was a print head that was always slightly tilted to the left after homing. That was fun to solve. 😉
If your bed is actually tilted that much relative to the frame of the printer (which is a lot for a mini) you can use shims to physically level the bed. I think the bed tilt process in marlin (I’m on klipper now) is good for something like a 0.5mm error. Anything over and it’s not fully fixable in software. I had this issue with my Taz6 bed and used [the process outlined in this thread](https://forum.lulzbot.com/t/solved-taz-6-auto-leveling-is-0-5mm-off-now-perfect-to-0-01mm/6250/29) to get things levelling consistently.
_[View the full topic](https://forum.lulzbot.com/t/mini-2-0-bed-not-level-with-x-axis/23545)._
