# MINI 2: Z height issue with varying XY for new machine
**URL:** <https://forum.lulzbot.com/t/mini-2-z-height-issue-with-varying-xy-for-new-machine/6046>\
**Category:** LulzBot Mini\
**Created:** [July 22, 2018, 9:24pm UTC](https://forum.lulzbot.com/t/mini-2-z-height-issue-with-varying-xy-for-new-machine/6046 "2018-07-22T21:24:28Z")\
**Posts on this page:** 1\
**Showing post:** 18
**Author:** ![Rorbot](https://avatars.discourse-cdn.com/v4/letter/r/96bed5/32.png) [@Rorbot](https://forum.lulzbot.com/u/Rorbot)\
**Post date:** [January 3, 2021, 5:04am UTC](https://forum.lulzbot.com/t/mini-2-z-height-issue-with-varying-xy-for-new-machine/6046/18 "2021-01-03T05:04:53Z")
Definitely fair enough 🙂
I continued some troubleshooting and ended up figuring out that there must’ve been a film of some sort deposited on one of my washers that, whatever it was, wasn’t cleaning off with just alcohol. I manually positioned and tested the nozzle against the washers using the M119 command in the terminal to report if z-min was triggered or not, and all but the one were very consistent (thus suggesting it’s on the washer’s end vs. the print head). After checking and double checking the continuity of the hookups, I finally tried cleaning the washer with some DeoxIT contact cleaner – getting some pretty solid first layers now and no longer observing the probe anomaly!
While it wasn’t ultimately helpful in resolving the issue for me, there were some useful tidbits in this thread (in case someone lands here trying to troubleshoot their unique woes):
> [@Lulzbot Mini 2 Inital Probe Failing (Zero volts read between washer/nozzle)](https://forum.lulzbot.com/t/lulzbot-mini-2-inital-probe-failing-zero-volts-read-between-washer-nozzle/20433):
> I recently purchased my third Lulzbot, Mini 2, and have only been able to have about 5 successful prints. Other than that it is failing to do an initial probe. The nozzle crashes into the first washer and starts the rewipe process. It does this over and over until the printer crashes. I get the same issue when I switch to a SL toolhead. I have replaced my wiping pad and have checked my washes and their connections. I have checked the tool head connections but cannot get the thing to probe corre…
I did end up going into the electrical box on mine in my desperation, and found that there were some very precarious connections due to the adhesive cable anchors they use for the assembly becoming unstuck and dislodged. I imagine it was only a matter of time that the resulting tension on the wires in conjunction with vibrations during printing might have caused an even bigger headache for me down the line 😅 I repositioned some of the wires to relieve this, giving up on the anchors entirely.
Anyway – thanks for the response, @scotchtape! Your remedy for what seems to be a poor system design seems to be working for you, so I might call it a simple solution to an overly complex problem over a stupid hack 🙂
Be well!
_[View the full topic](https://forum.lulzbot.com/t/mini-2-z-height-issue-with-varying-xy-for-new-machine/6046)._
