# Mini - Host Disconnect
**URL:** <https://forum.lulzbot.com/t/mini-host-disconnect/1669>\
**Category:** LulzBot Mini\
**Created:** [April 20, 2015, 8:48pm UTC](https://forum.lulzbot.com/t/mini-host-disconnect/1669 "2015-04-20T20:48:02Z")\
**Posts on this page:** 3\
**Post date:** [April 20, 2015, 8:48pm UTC](https://forum.lulzbot.com/t/mini-host-disconnect/1669/1 "2015-04-20T20:48:02Z")
I have noticed the Mini becoming unresponsive after it completes a print. It doesn’t matter if I am using Cura, Simplify3D or Octoprint as a host. I always have to click the disconnect button then reconnect before I can jog the printer.
I don’t see anything in the gcode that would cause this but I am a gcode newb.
Is anyone else experiencing this behavior / found a way to fix it?
**Author:** ![DawgBone](https://avatars.discourse-cdn.com/v4/letter/d/f07891/32.png) [@DawgBone](https://forum.lulzbot.com/u/DawgBone)\
**Post date:** [April 21, 2015, 5:02am UTC](https://forum.lulzbot.com/t/mini-host-disconnect/1669/2 "2015-04-21T05:02:45Z")
What OS are you using?
I’m not familiar with the connect/disconnect button…
I’m new, but using Windows and Cura… Cura has a direct serial connection to the printer.
Just curious if you’re using a Mac or Linux version?
Is there a sort of “middleman” or a shared USB hub?
**Post date:** [April 21, 2015, 11:53am UTC](https://forum.lulzbot.com/t/mini-host-disconnect/1669/3 "2015-04-21T11:53:26Z")
I am on Win8.1.
In Cura I have to close the printer control window and reopen it to reconnect to the printer. The other hosts have a connect / disconnect button.
It doesn’t matter if I am on a USB hub or directly connected to a PC or Raspberry Pi. I always have to reconnect…
