# Mini no longer actually printing
**URL:** <https://forum.lulzbot.com/t/mini-no-longer-actually-printing/4962>\
**Category:** Software\
**Created:** [June 10, 2017, 5:59pm UTC](https://forum.lulzbot.com/t/mini-no-longer-actually-printing/4962 "2017-06-10T17:59:35Z")\
**Posts on this page:** 1\
**Author:** ![StickyC](https://sea2.discourse-cdn.com/flex020/user_avatar/forum.lulzbot.com/stickyc/32/95_2.png) [@StickyC](https://forum.lulzbot.com/u/StickyC)\
**Post date:** [June 10, 2017, 5:59pm UTC](https://forum.lulzbot.com/t/mini-no-longer-actually-printing/4962/1 "2017-06-10T17:59:35Z")
After a long time (months) of sitting idle, I decided to start playing with the Mini again.
I’m running into a really weird issue when trying to print - The printer will go through the initialization/cleaning/calibration routine just fine, move the head into position to start the print, then immediately go to the cooldown routine without actually printing anything. All axis seem to work fine. Bed and extruder temps appear to track correctly.
I’ve tried this from both Octoprint on a RASPI 3 and from the Lulzbot Cura edition on OS-X.
Tried multiple STL files that have worked fine in the past - slicing from scratch.
Tried with both ABS and PLA (changing the slicer settings for each).
Re-installed the ‘default’ firmware from the Lulzbot Cura.
Any ideas where to look?
Output from Cura’s slicer:
```nohighlight
Running: /private/var/folders/dn/jl9dhjpn0n70f09vgld388fm0000gn/T/AppTranslocation/992648AF-7B54-42A7-8950-58BC4060EBAC/d/Cura.app/Contents/Resources/CuraEngine -v -p -s initialSpeedupLayers=4 -s minimalFeedrate=10 -s preSwitchExtruderCode=;Switch between the current extruder and the next extruder, when printing with multiple extruders.
;This code is added before the T(n)
 -s supportXYDistance=1500 -s insetXSpeed=35 -s retractionZHop=100 -s extruderOffset[3].X=0 -s extruderOffset[3].Y=0 -s postSwitchExtruderCode=;Switch between the current extruder and the next extruder, when printing with multiple extruders.
;This code is added after the T(n)
 -s retractionSpeed=10 -s filamentFlow=100 -s infillOverlap=15 -s inset0Speed=30 -s coolHeadLift=0 -s extrusionWidth=500 -s upSkinCount=4 -s initialLayerSpeed=15 -s minimalLayerTime=30 -s infillSpeed=40 -s supportExtruder=-1 -s fanSpeedMax=100 -s supportType=1 -s enableCombing=1 -s fanSpeedMin=100 -s supportZDistance=150 -s supportEverywhere=0 -s filamentDiameter=2850 -s initialLayerThickness=425 -s supportAngle=-1 -s fanFullOnLayerNr=1 -s extruderOffset[1].X=0 -s extruderOffset[1].Y=21600 -s layerThickness=250 -s endCode=M400
M104 S0 ; hotend off
M140 S0 ; heated bed heater off (if you have it)
M107 ; fans off
G92 E5 ; set extruder to 5mm for retract on print end
G1 X5 Y5 Z158 E0 F10000 ; move to cooling positioning
M190 R45 ; wait for bed to cool
M140 S0 ;
G1 X145 F1000 ; move to cooling positioning
G1 Y175 F1000 ; move to cooling positioning
M84 ; steppers off
G90 ; absolute positioning
;CURA_PROFILE_STRING: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
 -s minimalExtrusionBeforeRetraction=5 -s retractionMinimalDistance=1500 -s skirtMinLength=250000 -s objectSink=0 -s retractionAmount=1750 -s skinSpeed=30 -s skirtLineCount=1 -s startCode=;This Gcode has been generated specifically for the LulzBot Mini
;Basic settings: Layer height: 0.25 Walls: 1 Fill: 20
;Filament Diameter: 2.85
;Nozzle Size: 0.5
G26 ; clear potential 'probe fail' condition
G21 ; metric values
M107 ; start with the fan off
M140 S60; get bed heating up
G28 ; home all
M109 R140 ; set to cleaning temp and wait
G1 Z150 E-30 F75 ; suck up XXmm of filament
M109 R140 ; heat up rest of way
G1 X45 Y174 F11520 ; move behind scraper
G1 Z0 F1200 ; CRITICAL: set Z to height of top of scraper
G1 X45 Y174 Z-.5 F4000 ; wiping ; plunge into wipe pad
G1 X55 Y172 Z-.5 F4000 ; wiping
G1 X45 Y174 Z0 F4000 ; wiping
G1 X55 Y172 F4000 ; wiping
G1 X45 Y174 F4000 ; wiping
G1 X60 Y174 F4000 ; wiping
G1 X80 Y172 F4000 ; wiping
G1 X90 Y172 F4000 ; wiping
G1 X80 Y174 F4000 ; wiping
G1 X100 Y172 F4000 ; wiping
G1 X110 Y174 F4000 ; wiping
G1 X115 Y172 Z-0.5 F1000 ; wipe slower and bury noz in cleanish area
G1 Z10 ; raise z
G28 X0 Y0 ; home x and y
M109 R140 ; set to probing temp
M204 S300 ; Set probing acceleration
G29 ; Probe
M204 S2000 ; Restore standard acceleration
G1 X5 Y15 Z10 F5000 ; get out the way
G4 S1 ; pause
M400 ; clear buffer
M109 R205 ; set extruder temp and wait
G4 S15 ; wait for bed to temp up
G1 Z2 E0 F75 ; extrude filament back into nozzle
M140 S60; get bed temping up during first layer
 -s skirtDistance=3000 -s zOffset=0 -s extruderOffset[2].Y=0 -s extruderOffset[2].X=0 -s perimeterBeforeInfill=1 -s printSpeed=50 -s fixHorrible=1 -s layer0extrusionWidth=625 -s moveSpeed=175 -s supportLineDistance=1666 -s retractionAmountExtruderSwitch=16500 -s sparseInfillLineDistance=2500 -s insetCount=2 -s downSkinCount=4 -s multiVolumeOverlap=150 -g 49674 -m 1.0,0.0,0.0,0.0,1.0,0.0,0.0,0.0,1.0 -s posx=80000 -s posy=78000 $
Cura_SteamEngine version 21.04
Copyright (C) 2014 David Braam
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU Affero General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU Affero General Public License for more details.
You should have received a copy of the GNU Affero General Public License
along with this program. If not, see <http://www.gnu.org/licenses/>.
Default config 'default.cfg' not used
Reading mesh from socket with 960 vertexes
Loaded from disk in 0.003s
Analyzing and optimizing model...
Face counts: 320 -> 320 100.0%
Vertex counts: 960 -> 160 16.7%
Size: 22.500000 22.500000 10.000000
vMin: 68.750000 66.750000 0.000000
vMax: 91.250000 89.250000 10.000000
vMin: -11.250000 -11.250000 0.000000
vMax: 11.250000 11.250000 10.000000
Matrix: 1.000000 0.000000 0.000000
Matrix: 0.000000 1.000000 0.000000
Matrix: 0.000000 0.000000 1.000000
Optimize model 0.000s
Slicing model...
Layer count: 39
Sliced model in 0.014s
Generating support map...
Generating layer parts...
Generated layer parts in 0.002s
Generated inset in 0.005s
Generated up/down skin in 0.000s
Wrote layers in 0.00s.
Total time elapsed 0.02s.
Slicer process returned : 0
Output from Octoprint:
```nohighlight
Changing monitoring state from 'Connecting' to 'Operational'
Send: N0 M110 N0*125
Recv: ok
Send: N1 M115*39
Recv: FIRMWARE_NAME:Marlin 1.1.0.11 (Aleph Objects Inc.'s Phabricator) SOURCE_CODE_URL:https://code.alephobjects.com/diffusion/MARLIN PROTOCOL_VERSION:1.0 MACHINE_TYPE:LulzBot Mini EXTRUDER_COUNT:1 UUID:351487b6-ca9a-4c1a-8765-d668b1da6585
Recv: ok
Send: M21
Recv: ok
Send: M115
Recv: ok
Send: M105
Recv: ok T:84.4 /0.0 B:41.8 /0.0 B@:0 @:0
Send: M105
Recv: ok T:83.7 /0.0 B:41.8 /0.0 B@:0 @:0
Send: M105
Recv: ok T:83.0 /0.0 B:41.9 /0.0 B@:0 @:0
Send: M105
Recv: ok T:82.3 /0.0 B:41.8 /0.0 B@:0 @:0
Send: M105
Recv: ok T:81.6 /0.0 B:41.5 /0.0 B@:0 @:0
Send: M105
Recv: ok T:80.9 /0.0 B:41.3 /0.0 B@:0 @:0
Send: M105
Recv: ok T:80.3 /0.0 B:41.0 /0.0 B@:0 @:0
Changing monitoring state from 'Operational' to 'Printing'
Recv: ok
Send: N1 G21*27
Recv: ok
Send: N2 G90*18
Recv: ok
Send: N3 M82*26
Recv: ok
Send: N4 M107*33
Recv: ok
Send: N5 G92 E0*66
Recv: ok
Send: N6 M140 S60*85
Recv: ok
Send: N7 G28*20
Recv: X:0.00 Y:191.00 Z:159.00 E:0.00 Count X: 0 Y:19196 Z:254400
Recv: ok
Send: N8 M109 S140*101
Recv: T:78.5 /140.0 B:43.4 /60.0 B@:127 @:0 W:?
Recv: T:78.3 /140.0 B:43.6 /60.0 B@:127 @:127 W:?
Recv: T:78.2 /140.0 B:43.8 /60.0 B@:127 @:127 W:?
Recv: T:78.2 /140.0 B:44.3 /60.0 B@:127 @:127 W:?
Recv: T:78.5 /140.0 B:44.6 /60.0 B@:127 @:127 W:?
Recv: T:78.8 /140.0 B:45.3 /60.0 B@:127 @:127 W:?
Recv: T:79.3 /140.0 B:45.8 /60.0 B@:127 @:127 W:?
Recv: T:79.8 /140.0 B:45.8 /60.0 B@:127 @:127 W:?
Recv: T:80.6 /140.0 B:46.3 /60.0 B@:127 @:127 W:?
Recv: T:81.5 /140.0 B:47.0 /60.0 B@:127 @:127 W:?
Recv: T:82.5 /140.0 B:47.5 /60.0 B@:127 @:127 W:?
Recv: T:83.6 /140.0 B:47.6 /60.0 B@:127 @:127 W:?
Recv: T:84.8 /140.0 B:48.1 /60.0 B@:127 @:127 W:?
Recv: T:86.3 /140.0 B:48.6 /60.0 B@:127 @:127 W:?
Recv: T:87.5 /140.0 B:48.6 /60.0 B@:127 @:127 W:?
Recv: T:89.0 /140.0 B:49.2 /60.0 B@:127 @:127 W:?
Recv: T:90.6 /140.0 B:50.0 /60.0 B@:127 @:127 W:?
Recv: T:91.9 /140.0 B:50.2 /60.0 B@:127 @:127 W:?
Recv: T:93.7 /140.0 B:50.3 /60.0 B@:127 @:127 W:?
Recv: T:95.5 /140.0 B:50.6 /60.0 B@:127 @:127 W:?
Recv: T:97.1 /140.0 B:50.9 /60.0 B@:127 @:127 W:?
Recv: T:98.8 /140.0 B:51.5 /60.0 B@:127 @:127 W:?
Recv: T:100.4 /140.0 B:51.6 /60.0 B@:127 @:127 W:?
Recv: T:102.1 /140.0 B:52.1 /60.0 B@:127 @:127 W:?
Recv: T:103.8 /140.0 B:52.4 /60.0 B@:127 @:127 W:?
Recv: T:105.5 /140.0 B:52.7 /60.0 B@:127 @:127 W:?
Recv: T:107.3 /140.0 B:53.0 /60.0 B@:127 @:127 W:?
Recv: T:109.0 /140.0 B:53.3 /60.0 B@:127 @:127 W:?
Recv: T:110.8 /140.0 B:53.6 /60.0 B@:127 @:127 W:?
Recv: T:112.3 /140.0 B:53.9 /60.0 B@:127 @:127 W:?
Recv: T:114.2 /140.0 B:54.1 /60.0 B@:127 @:127 W:?
Recv: T:116.3 /140.0 B:54.5 /60.0 B@:127 @:127 W:?
Recv: T:117.8 /140.0 B:54.9 /60.0 B@:127 @:127 W:?
Recv: T:119.5 /140.0 B:55.6 /60.0 B@:127 @:127 W:?
Recv: T:121.0 /140.0 B:55.4 /60.0 B@:127 @:127 W:?
Recv: T:122.9 /140.0 B:55.8 /60.0 B@:127 @:127 W:?
Recv: T:124.6 /140.0 B:55.9 /60.0 B@:127 @:127 W:?
Recv: T:126.3 /140.0 B:56.3 /60.0 B@:127 @:127 W:?
Recv: T:128.0 /140.0 B:56.3 /60.0 B@:127 @:127 W:?
Recv: T:129.6 /140.0 B:56.7 /60.0 B@:127 @:127 W:?
Recv: T:131.2 /140.0 B:57.1 /60.0 B@:127 @:44 W:0
Recv: ok
Send: N9 G1 Z150 E-30 F75*64
Recv: ok
Send: N10 M109 S140*92
Recv: T:131.6 /140.0 B:57.2 /60.0 B@:127 @:38 W:?
Recv: T:133.2 /140.0 B:57.4 /60.0 B@:127 @:22 W:0
Recv: ok
Send: N11 G1 X45 Y174 F11520*123
Recv: ok
Send: N12 G1 Z0 F1200*20
Recv: ok
Send: N13 G1 X45 Y174 Z-.5 F4000*6
Recv: ok
Send: N14 G1 X55 Y172 Z-.5 F4000*6
Recv: ok
Send: N15 G1 X45 Y174 Z0 F4000*6
Recv: ok
Send: N16 G1 X55 Y172 F4000*72
Recv: ok
Send: N17 G1 X45 Y174 F4000*78
Recv: ok
Send: N18 G1 X55 Y172 F4000*70
Recv: ok
Send: N19 G1 X45 Y174 F4000*64
Recv: ok
Send: N20 G1 X55 Y172 F4000*77
Recv: ok
Send: N21 G1 X60 Y174 F4000*76
Recv: ok
Send: N22 G1 X80 Y172 F4000*71
Recv: ok
Send: N23 G1 X60 Y174 F4000*78
Recv: ok
Send: N24 G1 X80 Y172 F4000*65
Recv: ok
Send: N25 G1 X60 Y174 F4000*72
Recv: ok
Send: N26 M105*19
Recv: ok T:140.3 /140.0 B:59.1 /60.0 B@:127 @:0
Send: N27 G1 X90 Y172 F4000*67
Recv: ok
Send: N28 G1 X80 Y174 F4000*75
Recv: ok
Send: N29 M105*28
Recv: ok T:141.9 /140.0 B:60.0 /60.0 B@:76 @:7
Send: N30 G1 X100 Y172 F4000*125
Recv: ok
Send: N31 G1 X80 Y174 F4000*67
Recv: ok
Send: N32 G1 X100 Y172 F4000*127
Recv: ok
Send: N33 G1 X80 Y174 F4000*65
Recv: ok
Send: N34 G1 X100 Y172 F4000*121
Recv: ok
Send: N35 M105*17
Recv: ok T:141.8 /140.0 B:60.1 /60.0 B@:48 @:9
Send: N36 G1 X110 Y174 F4000*124
Recv: ok
Send: N37 G1 X100 Y172 F4000*122
Recv: ok
Send: N38 G1 X110 Y174 F4000*114
Recv: ok
Send: N39 G1 X100 Y172 F4000*116
Recv: ok
Send: N40 G1 X110 Y174 F4000*125
Recv: ok
Send: N41 G1 X115 Y172 Z-0.5 F1000*6
Recv: ok
Send: N42 G1 Z10*101
Recv: ok
Send: N43 G28 X0 Y0*37
Recv: X:0.00 Y:191.00 Z:10.00 E:-30.00 Count X: 0 Y:19196 Z:16000
Recv: ok
Send: N44 M109 S140*93
Recv: T:139.7 /140.0 B:59.7 /60.0 B@:112 @:31 W:?
Recv: T:139.6 /140.0 B:59.7 /60.0 B@:120 @:30 W:0
Recv: ok
Send: N45 M204 S300*84
Recv: Setting Print and Travel Acceleration: 300.00
Recv: ok
Send: N46 G29*32
Recv: G29 Auto Bed Leveling
Recv: Eqn coefficients: a: 0.00779567 b: -0.00065548 d: -2.51849794
Recv:
Recv:
Recv: Bed Level Correction Matrix:
Recv: +0.999970 +0.000000 +0.007795
Recv: +0.000005 +1.000000 -0.000655
Recv: -0.007795 +0.000655 +0.999969
Recv: X:-0.02 Y:162.00 Z:1.43 E:-30.00 Count X: -3 Y:16281 Z:2118
Recv: ok
Send: N47 M204 S2000*103
Recv: Setting Print and Travel Acceleration: 2000.00
Recv: ok
Send: N48 G1 X5 Y15 Z10 F5000*60
Recv: ok
Send: N49 G4 S1*82
Recv: ok
Send: N50 M400*18
Recv: ok
Send: N51 M109 S205*91
Recv: T:139.7 /205.0 B:60.2 /60.0 B@:3 @:26 W:?
Recv: T:139.8 /205.0 B:60.2 /60.0 B@:0 @:127 W:?
Recv: T:139.7 /205.0 B:60.1 /60.0 B@:28 @:127 W:?
Recv: T:139.7 /205.0 B:60.0 /60.0 B@:39 @:127 W:?
Recv: T:140.1 /205.0 B:60.1 /60.0 B@:17 @:127 W:?
Recv: T:140.5 /205.0 B:60.2 /60.0 B@:0 @:127 W:?
Recv: T:141.3 /205.0 B:60.0 /60.0 B@:37 @:127 W:?
Recv: T:141.7 /205.0 B:60.1 /60.0 B@:23 @:127 W:?
Recv: T:142.6 /205.0 B:60.3 /60.0 B@:0 @:127 W:?
Recv: T:143.5 /205.0 B:60.1 /60.0 B@:16 @:127 W:?
Recv: T:144.4 /205.0 B:60.0 /60.0 B@:32 @:127 W:?
Recv: T:145.8 /205.0 B:60.3 /60.0 B@:0 @:127 W:?
Recv: T:146.8 /205.0 B:60.1 /60.0 B@:23 @:127 W:?
Recv: T:148.0 /205.0 B:59.9 /60.0 B@:51 @:127 W:?
Recv: T:149.3 /205.0 B:59.8 /60.0 B@:70 @:127 W:?
Recv: T:150.3 /205.0 B:60.0 /60.0 B@:30 @:127 W:?
Recv: T:151.8 /205.0 B:60.0 /60.0 B@:28 @:127 W:?
Recv: T:153.1 /205.0 B:59.9 /60.0 B@:54 @:127 W:?
Recv: T:154.5 /205.0 B:59.9 /60.0 B@:52 @:127 W:?
Recv: T:155.6 /205.0 B:60.0 /60.0 B@:34 @:127 W:?
Recv: T:157.3 /205.0 B:60.2 /60.0 B@:1 @:127 W:?
Recv: T:158.5 /205.0 B:60.1 /60.0 B@:7 @:127 W:?
Recv: T:159.7 /205.0 B:59.9 /60.0 B@:42 @:127 W:?
Recv: T:161.9 /205.0 B:60.1 /60.0 B@:13 @:127 W:?
Recv: T:163.4 /205.0 B:60.2 /60.0 B@:0 @:127 W:?
Recv: T:164.4 /205.0 B:60.1 /60.0 B@:13 @:127 W:?
Recv: T:166.1 /205.0 B:60.0 /60.0 B@:36 @:127 W:?
Recv: T:167.5 /205.0 B:59.9 /60.0 B@:43 @:127 W:?
Recv: T:169.1 /205.0 B:60.0 /60.0 B@:36 @:127 W:?
Recv: T:169.9 /205.0 B:60.0 /60.0 B@:27 @:127 W:?
Recv: T:172.2 /205.0 B:60.1 /60.0 B@:14 @:127 W:?
Recv: T:173.8 /205.0 B:60.0 /60.0 B@:33 @:127 W:?
Recv: T:174.5 /205.0 B:59.8 /60.0 B@:71 @:127 W:?
Recv: T:176.6 /205.0 B:60.0 /60.0 B@:26 @:127 W:?
Recv: T:178.1 /205.0 B:60.2 /60.0 B@:0 @:127 W:?
Recv: T:179.6 /205.0 B:60.0 /60.0 B@:36 @:127 W:?
Recv: T:180.4 /205.0 B:60.0 /60.0 B@:32 @:127 W:?
Recv: T:182.7 /205.0 B:60.2 /60.0 B@:0 @:127 W:?
Recv: T:184.1 /205.0 B:60.2 /60.0 B@:0 @:127 W:?
Recv: T:185.9 /205.0 B:60.1 /60.0 B@:17 @:127 W:?
Recv: T:187.4 /205.0 B:59.9 /60.0 B@:56 @:127 W:?
Recv: T:187.9 /205.0 B:60.0 /60.0 B@:19 @:127 W:?
Recv: T:190.1 /205.0 B:59.9 /60.0 B@:43 @:127 W:?
Recv: T:191.2 /205.0 B:59.8 /60.0 B@:66 @:127 W:?
Recv: T:192.5 /205.0 B:60.0 /60.0 B@:29 @:127 W:?
Recv: T:194.7 /205.0 B:60.1 /60.0 B@:7 @:127 W:?
Recv: T:195.6 /205.0 B:60.2 /60.0 B@:0 @:65 W:0
Recv: ok
Send: N52 G4 S15*109
Recv: ok
Send: N53 G1 Z2 E0 F75*103
Recv: ok
Send: N54 M140 S60*98
Recv: ok
Send: N55 M107*21
Recv: ok
Send: N56 M106 S191*93
Recv: ok
Send: N57 M107*23
Recv: ok
Send: N58 G1 F600 E-1.50000*39
Recv: ok
Send: N59 G1 Z0.100*65
Recv: ok
Send: N60 G0 F10500 X0.000 Y0.000 Z15.000*44
Recv: ok
Send: N61 M400*16
Recv: ok
Send: N62 M104 S0*81
Recv: echo:endstops hit: X:0.02
Recv: ok
Send: N63 M140 S0*80
Recv: ok
Send: N64 M107*23
Recv: ok
Send: N65 G92 E5*113
Recv: ok
Send: N66 G1 X5 Y5 Z156 E0 F10000*83
Recv: ok
Send: N67 M190 R50*109
Recv: T:204.2 /0.0 B:60.1 /50.0 B@:7 @:59 W:?
(snipped)
Recv: T:135.2 /0.0 B:51.1 /50.0 B@:0 @:0 W:?
Recv: T:134.8 /0.0 B:51.1 /50.0 B@:0 @:0 W:0
Recv: ok
Send: N68 M140 S0*91
Recv: ok
Send: N69 G1 X145 Y175 Z156 F1000*58
Recv: ok
Send: N70 M84*40
Recv: ok
Send: N71 M105*17
Recv: ok T:130.4 /0.0 B:50.7 /0.0 B@:0 @:0
Send: N72 G90*37
Recv: ok
Changing monitoring state from 'Printing' to 'Operational'
Send: M105
Recv: ok T:129.8 /0.0 B:50.1 /0.0 B@:0 @:0
