# Mini Power Consumption Numbers
**URL:** <https://forum.lulzbot.com/t/mini-power-consumption-numbers/3961>\
**Category:** LulzBot Mini\
**Created:** [September 8, 2016, 12:20pm UTC](https://forum.lulzbot.com/t/mini-power-consumption-numbers/3961 "2016-09-08T12:20:37Z")\
**Posts on this page:** 7\
**Post date:** [September 8, 2016, 12:20pm UTC](https://forum.lulzbot.com/t/mini-power-consumption-numbers/3961/1 "2016-09-08T12:20:37Z")
We ran a test last night for testing the Mini’s power consumption for those who had been asking in the past.
The results are as follows:
While heating up, the mini pulls ~190W. Once heated, the mini pulses the nozzle on and off so your peak wattage is 180W and drops to as low as 54W with about a 50% duty cycle.
**For a 45 minute print, the mini used 0.11kW**
The average price per kW/hr in the US is $0.12.
**Based on this, if you printed constantly, you’d spend about $0.02/hour, $0.42/day, and $2.95/week to 3D print.**
A few people asked about how much it costs to let your printer run idle…
**The printer was left running idle for 2 hours and the meter had yet to register any Wattage. I think it’s safe to say it’s next to nothing.** You’ll probably spend more replacing your electronics case cooling fan from having it run 24-7 🙂
-Jim
**Author:** ![luckyj](https://avatars.discourse-cdn.com/v4/letter/l/7feea3/32.png) [@luckyj](https://forum.lulzbot.com/u/luckyj)\
**Post date:** [September 8, 2016, 2:32pm UTC](https://forum.lulzbot.com/t/mini-power-consumption-numbers/3961/2 "2016-09-08T14:32:13Z")
Hey Jim, thanks for posting that info. I had a kill-a-watt hooked up and looked at the numbers when I first got my printer…though I don’t remember exactly what they were, pretty sure it was around what you saw. Maybe I’ll check it out again during my next print and compare.
On the topic of idle power consumption, I am seeing ~2.3 watts of continuous power draw when the printer is idle. That won’t add up to a lot of kWh, but there is some measurable power consumption even when idle.
**Post date:** [September 8, 2016, 3:15pm UTC](https://forum.lulzbot.com/t/mini-power-consumption-numbers/3961/3 "2016-09-08T15:15:41Z")
> [@luckyj](#):
I’m not claiming it’s zero. There’s obviously some draw there, but in the grand scheme of things, you can probably more than offset the cost of your printer running idle by checking your couch cushions or checking in your cup holder in your car 🙂
Worded differently…if you can’t afford the electric bill associated with leaving your printer running idle, you probably shouldn’t be 3D printing and concentrate more on staving off starvation. 🙂
**Author:** ![joshea](https://sea2.discourse-cdn.com/flex020/user_avatar/forum.lulzbot.com/joshea/32/10277_2.png) [@joshea](https://forum.lulzbot.com/u/joshea)\
**Post date:** [September 8, 2016, 5:48pm UTC](https://forum.lulzbot.com/t/mini-power-consumption-numbers/3961/4 "2016-09-08T17:48:15Z")
Thanks for this.
Some time back a co-worker of mine though my power bill would go up with my printer. I started to look online and that didn’t seem to be the case, but I wasn’t sure. Reading this helps assure that.
Another reason to love my printer, lower power costs!
**Post date:** [September 8, 2016, 8:05pm UTC](https://forum.lulzbot.com/t/mini-power-consumption-numbers/3961/5 "2016-09-08T20:05:43Z")
> [@joshea](#):
> Thanks for this.
If you lived in a really small house, you could run your printer and turn off your HVAC in which case your 3d printer might actually lower your bill.
It would have to be a very very tiny house 🙂
**Author:** ![creamywasher](https://avatars.discourse-cdn.com/v4/letter/c/df788c/32.png) [@creamywasher](https://forum.lulzbot.com/u/creamywasher)\
**Post date:** [July 31, 2018, 10:01am UTC](https://forum.lulzbot.com/t/mini-power-consumption-numbers/3961/6 "2018-07-31T10:01:52Z")
How can i reduce my electricity cost?
**Post date:** [July 31, 2018, 5:51pm UTC](https://forum.lulzbot.com/t/mini-power-consumption-numbers/3961/7 "2018-07-31T17:51:20Z")
> > [@joshea](#):
> > Thanks for this.
Yeah that’s, kind of pushing it for me.
