# My TAZ 5 stops and no longer wants to print
**URL:** <https://forum.lulzbot.com/t/my-taz-5-stops-and-no-longer-wants-to-print/4974>\
**Created:** [June 15, 2017, 3:08pm UTC](https://forum.lulzbot.com/t/my-taz-5-stops-and-no-longer-wants-to-print/4974 "2017-06-15T15:08:58Z")\
**Posts on this page:** 5\
**Author:** ![Ernesto\_Renteria](https://avatars.discourse-cdn.com/v4/letter/e/b4bc9f/32.png) [@Ernesto\_Renteria](https://forum.lulzbot.com/u/Ernesto_Renteria)\
**Post date:** [June 15, 2017, 3:08pm UTC](https://forum.lulzbot.com/t/my-taz-5-stops-and-no-longer-wants-to-print/4974/1 "2017-06-15T15:08:58Z")
Everything was fine but today the printer no longer wants to print, when I want to make a piece the printer starts well, but suddenly stops and no longer continues. Already try to pause it and give it continue, does the calibration movement but does not continue with the work.
Cancel the works, the command to print again but the same thing happens again.
**Post date:** [June 15, 2017, 7:54pm UTC](https://forum.lulzbot.com/t/my-taz-5-stops-and-no-longer-wants-to-print/4974/2 "2017-06-15T19:54:57Z")
> [@Ernesto Renteria](#):
What does your serial terminal say when it stops?
Does your temperature of your nozzle and bed go up or stay at room temp?
**Post date:** [June 15, 2017, 10:34pm UTC](https://forum.lulzbot.com/t/my-taz-5-stops-and-no-longer-wants-to-print/4974/3 "2017-06-15T22:34:43Z")
Hi Jim
The terminal remains as if the machine is printing.
The room is cold but the bed and nozzle temperature stays warm.
**Author:** ![Rookie](https://avatars.discourse-cdn.com/v4/letter/r/e47c2d/32.png) [@Rookie](https://forum.lulzbot.com/u/Rookie)\
**Post date:** [June 16, 2017, 1:39am UTC](https://forum.lulzbot.com/t/my-taz-5-stops-and-no-longer-wants-to-print/4974/4 "2017-06-16T01:39:09Z")
Was you STL file clean? Did you run it through a mesh mixer and correct errors? That got me once.
[https://forum.lulzbot.com/t/taz-5-stops/1959/1](https://forum.lulzbot.com/t/taz-5-stops/1959/1)
**Post date:** [June 16, 2017, 5:53pm UTC](https://forum.lulzbot.com/t/my-taz-5-stops-and-no-longer-wants-to-print/4974/5 "2017-06-16T17:53:31Z")
After two attempts and to restart the computer, the printer finished the piece.
It is a simple but large piece, I did not verify the STL file, I do not know how to do it.
