# Nozzles for Hexagon Hotend
**URL:** <https://forum.lulzbot.com/t/nozzles-for-hexagon-hotend/5505>\
**Created:** [January 17, 2018, 4:53am UTC](https://forum.lulzbot.com/t/nozzles-for-hexagon-hotend/5505 "2018-01-17T04:53:16Z")\
**Posts on this page:** 4\
**Author:** ![vreahli](https://sea2.discourse-cdn.com/flex020/user_avatar/forum.lulzbot.com/vreahli/32/9636_2.png) [@vreahli](https://forum.lulzbot.com/u/vreahli)\
**Post date:** [January 17, 2018, 4:53am UTC](https://forum.lulzbot.com/t/nozzles-for-hexagon-hotend/5505/1 "2018-01-17T04:53:16Z")
Hi!
I keep getting conflicting answers - can I use an 3mm e3d v6 nozzle on a hexagon hotend? Will most m6 threaded nozzles work on this hotend?
Thanks in advance!
**Post date:** [January 20, 2018, 8:56pm UTC](https://forum.lulzbot.com/t/nozzles-for-hexagon-hotend/5505/2 "2018-01-20T20:56:26Z")
Yes, you can 100% use a 3mm (or 1.75mm too if you wanted to also convert the barrel and extruder) E3dV6 nozzle in a hexagon. The only one you cannot use is one of the ruby tipped ones in a Taz 6 or a Mini because it doesn’t conduct electricity for the auto leveling contact with the corners. Most of the M6 threaded ones will work assuming they are electrically conductive.
edit: The super long nozzles like the ones intended for the volcano would fit, but you should avoid them for physics reasons dealing with cooling rates.
**Author:** ![tommyscanlon](https://avatars.discourse-cdn.com/v4/letter/t/e36b37/32.png) [@tommyscanlon](https://forum.lulzbot.com/u/tommyscanlon)\
**Post date:** [January 23, 2018, 7:27pm UTC](https://forum.lulzbot.com/t/nozzles-for-hexagon-hotend/5505/3 "2018-01-23T19:27:19Z")
?? can I use a larger nozzle - .6 or .8mm on m Taz-5 for larger projects that would take 30 hours to print with the 3.5mm OEM nozzle ???
— I assume that Cura would slice it correctly…
— a .8mm nozzle would allow five times the flow of a 3.5mm nozzle — (64 / 12.5) — but could the heater keep up with the faster demand ???
— tommy
**Post date:** [January 26, 2018, 7:47am UTC](https://forum.lulzbot.com/t/nozzles-for-hexagon-hotend/5505/4 "2018-01-26T07:47:11Z")
3.5mm nozzle? The .8 should work. Like you said, the speed might need tweaking… but the slicer should account for the necessary extrusion speed. Extruding a little hotter could help the extruder keep up.
The .8mm would only print faster if you set the layer height to .5 (60% of the nozzle opening). The print duration would probably the same if you printed at a layer height of .2 or .3. Reducing infill could help print duration, but the outer perimeter print speed would have the biggest effect on speed.
