# Polysmooth Profile
**URL:** <https://forum.lulzbot.com/t/polysmooth-profile/5982>\
**Category:** Filament\
**Created:** [June 25, 2018, 1:36am UTC](https://forum.lulzbot.com/t/polysmooth-profile/5982 "2018-06-25T01:36:04Z")\
**Posts on this page:** 2\
**Author:** ![OyarzoPablo](https://avatars.discourse-cdn.com/v4/letter/o/977dab/32.png) [@OyarzoPablo](https://forum.lulzbot.com/u/OyarzoPablo)\
**Post date:** [June 25, 2018, 1:36am UTC](https://forum.lulzbot.com/t/polysmooth-profile/5982/1 "2018-06-25T01:36:04Z")
1. Does anybody have a profile for the Polysmooth material?
I’m getting excess material on the sides (probably because of bad retraction settings) using the PLA Verbatim profile. I have the Taz 6 with the stock hot end…
1. Is there a tutorial on testing a material and creating a profile for it?
**Author:** ![Ehoff](https://avatars.discourse-cdn.com/v4/letter/e/3ab097/32.png) [@Ehoff](https://forum.lulzbot.com/u/Ehoff)\
**Post date:** [July 20, 2018, 1:39pm UTC](https://forum.lulzbot.com/t/polysmooth-profile/5982/2 "2018-07-20T13:39:52Z")
Here are the steps for creating a custom material/profile in Cura LE. I don’t have much advice on testing material, to create a profile for it, other than a note pad with notes about what seems to work and what seems to produce bad prints, also try not to make to many changes at once, otherwise you might be fighting more with settings than need be.
1. Load Cura make sure that in the ‘Material’ drop down menu on right side of screen you have your preferred filament selected.
2. Make sure you have the detail profile you want to print with selected from the ‘Profile’ drop down menu directly below ‘Material’ menu (Your new profile will be set to whatever detail profile you selected so if you want to print using our standard detail of .25mm you will have to make sure this is selected before moving forward).
3. Switch from ‘Recommended’ to ‘Custom’ settings if you are not already in the correct area by selecting the option for ‘Custom’ you can find this next to the area labled ‘Print Setup’.
4. Make any and all adjustments to the settings that you need.
5. Once changes have been made to the settings a star will appear in the drop down menu for ‘Profile’.
6. Click the arrow on 'Profile" drop down menu and select option labeled ‘Create New Profile From Current Settings/Overrides’.
7. This will bring up a new window in which you will be asked to name your new profile. We recommend labeling these something specific so they are easy to keep track of, but that is entirely up to you. You can then export the newly created profile from Cura, and import it into other materials that are using similar parameters for the profile drop down menu, without having to create a whole new profile.
8. Once your new profile has been saved you can select it by first choosing the Material that you used to create the profile then in the ‘Profile’ drop down menu select the new option that will be available from this menu. This new profile should include all the setting adjustments you just made.
