How is the Lulzbot factory printing the Blower Duct with no supports. The distance to bridge is way too long!
http://download.lulzbot.com/Mini/2.0.4/production_parts/printed_parts/blower_shroud/
Are you using ABS? I’ve been printing a bunch of factory parts for a mini i just got, I’ve been importing the gcode files into Cura, and printing those with really good success. I am using Cromastrand ABS which is what they use as well so it makes it easy.
Hello Iggy,
Thanks for the response! I haven’t tried anything yet because the bridge to close is so large that is doesn’t seem feasible. We are talking over an inch.
Totally! I should have mentioned that I’ve printed out 3 so far using the same material and gcode without problems. I had a issue printing one on my own with some problems. Then I loaded their Gcode in cura and used the same orientation for the top layers with the bridges and it printed just fine.
How did you remove the supports?
I didn’t print supports.
wow, so it bridged that huge gap! Amazing!!
Ok, I am going to try with PLA right now as I dont have any ABS on hand.
Just don’t use the Gcode if you use PLA since ABS prints at higher temperature.
Do you know which one it is?
M2_PP-GP0342_blower_duct_v2_x2_6-29-18.gcode | 2018-10-17 13:24 | 2.9M | |
PP-GP0342_blower_duct_v2_x2_2-14-18.gcode | 2018-10-17 13:24 | 2.9M |
I’m not 100% sure but I think one is for the mini and M2 is code for the mini 2.
Thanks a bunch for your help!
