I have been testing out some slicing software and have had luck using Skeinforge on my Solidoodle 4 but cant get anything going on the Taz4. Any advice from the group? Thanks!
Hah!
Yes. Use Cura or Slic3r.
I kid I kid!
Some of the best prints I had in 3D printing before Cura was with Skeinforge. It’s not the easiest program to pick up, but there’s a lot you could do with it. Sfact was an easier version of Skeinforge that had several settings tied into fewer variables.
You can achieve better results much more quickly and easily with Slic3r or Cura, using the premade profiles you have here:
https://www.lulzbot.com/support/taz-cura-profiles and https://www.lulzbot.com/support/taz-slic3r-profiles
You should be able to adapt your Skeinforge profile to work with the TAZ, but you’ll need to use it as a base then start tweaking. I don’t know of anyone that uses a TAZ and Skeinforge, as there’s better/easier/more friendly options out there.
It was nice having control over all the options though:
