Solid layers on last 2 layers only
Hi,
I have a design that technically has 2 tops. I want just the last 2 layers solid. Is there a gcode command for that?
Thanks in advance!!!
If you tell your slicer to create 2 top solid layers, both of your “2 tops” will have 2 top layers. Each upper surface gets the top solid layer count…
By the way, 2 solid top layers are usualy not enough to get a nice surface finish. Depending on your layer height, you may want a minimum of 3…
