# Taz 2.1 Y Axis Looseness
**URL:** <https://forum.lulzbot.com/t/taz-2-1-y-axis-looseness/365>\
**Created:** [December 14, 2013, 9:07pm UTC](https://forum.lulzbot.com/t/taz-2-1-y-axis-looseness/365 "2013-12-14T21:07:57Z")\
**Posts on this page:** 5\
**Post date:** [December 14, 2013, 9:07pm UTC](https://forum.lulzbot.com/t/taz-2-1-y-axis-looseness/365/1 "2013-12-14T21:07:57Z")
I noticed my new Taz had some noticeable bed “wiggle” when the Y axis would change directions. I removed the bed to check it out and found this.
Are any other users or LulzBot folks seeing this kind of clearance in the bushings?
[https://www.youtube.com/watch?v=JtWOkn\_jIO8&feature=youtube\_gdata\_player](https://www.youtube.com/watch?v=JtWOkn_jIO8&feature=youtube_gdata_player)
**Author:** ![Cale](https://avatars.discourse-cdn.com/v4/letter/c/ce7236/32.png) [@Cale](https://forum.lulzbot.com/u/Cale)\
**Post date:** [December 16, 2013, 3:11pm UTC](https://forum.lulzbot.com/t/taz-2-1-y-axis-looseness/365/2 "2013-12-16T15:11:04Z")
This can be adjusted out by loosening the bushing holders from the bed plate and turning them so that they stay in contact with the y-rods while traveling.
**Post date:** [December 16, 2013, 5:52pm UTC](https://forum.lulzbot.com/t/taz-2-1-y-axis-looseness/365/3 "2013-12-16T17:52:25Z")
Thanks. I will give it a shot.
Is there any reason I shouldn’t use a bearing, other than added noise?
**Post date:** [December 16, 2013, 9:13pm UTC](https://forum.lulzbot.com/t/taz-2-1-y-axis-looseness/365/4 "2013-12-16T21:13:27Z")
Nope, it’s just added noise. And added cost.
**Author:** ![Frakk](https://avatars.discourse-cdn.com/v4/letter/f/f17d59/32.png) [@Frakk](https://forum.lulzbot.com/u/Frakk)\
**Post date:** [December 18, 2013, 4:40am UTC](https://forum.lulzbot.com/t/taz-2-1-y-axis-looseness/365/5 "2013-12-18T04:40:31Z")
I too have the same amount of slop in the bushings, not sure if it’s a bad batch or meant to have that much, but it made my carriage move up-down about 0.5mm when changed X direction. I tightened it up following Caleb’s directions but it won’t be perfect.
I picked up replacement bearings for ~$1.20USD on fleabay, cheaper than the bushings so I’m hoping they are not total garbage. If they hold up and eliminate the ~1mm slop without misalignment, I’ll deal with a slightly louder machine any day.
