# Taz 6 + Filament Sentinel = Modified Firmware...
**URL:** <https://forum.lulzbot.com/t/taz-6-filament-sentinel-modified-firmware/5008>\
**Category:** Software\
**Created:** [June 27, 2017, 8:15pm UTC](https://forum.lulzbot.com/t/taz-6-filament-sentinel-modified-firmware/5008 "2017-06-27T20:15:59Z")\
**Posts on this page:** 5\
**Author:** ![Mulanzo](https://avatars.discourse-cdn.com/v4/letter/m/3ec8ea/32.png) [@Mulanzo](https://forum.lulzbot.com/u/Mulanzo)\
**Post date:** [June 27, 2017, 8:15pm UTC](https://forum.lulzbot.com/t/taz-6-filament-sentinel-modified-firmware/5008/1 "2017-06-27T20:15:59Z")
Hi All,
I bought a Filament Sentinel on Kickstarter because I print very large prints that tend to run out of filament. The instructions tell me that I need to make some firmware modifications:
**Wiring**
**Check your board specification for the required pins
Determine your [DIGITAL PIN INPUT] pin number, it will be required for firmware configuration. For example, RAMPS uses D4 (Digital pin number 4) by default.
Connect the wires**
**Firmware Config
Legend: Remove Modify**
**Configuration.h
//#define FILAMENT\_RUNOUT\_SENSOR**
**Configuration\_adv.h
//#define FILAMENT\_CHANGE\_FEATURE**
**Pins\_[BOARD NAME].h
 #define FIL\_RUNOUT\_PIN [DIGITAL PIN INPUT]**
**Please note!
If the above line isn’t present, simply add it**
I don’t know how to do this in the slightest. If I asked a kind soul on the forum to help me out would anyone be willing to either make the mod for me or tell me how to do it?
I don’t even know where to begin.
**Author:** ![nuroo](https://avatars.discourse-cdn.com/v4/letter/n/c89c15/32.png) [@nuroo](https://forum.lulzbot.com/u/nuroo)\
**Post date:** [September 13, 2017, 8:28pm UTC](https://forum.lulzbot.com/t/taz-6-filament-sentinel-modified-firmware/5008/2 "2017-09-13T20:28:59Z")
Hey Mulanzo,
This subject is very important to me also. Matter of fact I just posted a thread on doing the same thing with Octoprint in another section of this [forum.](https://forum.lulzbot.com/t/octoprint-filament-runout-sensor/5190/1) It’s miles easier to implement than using the sensor you brought.
If you dont have experience with compiling software, reading board schematics, modifying marlin, looking for available inputs on your ramps board, etc - it will be a tall order to explain in this thread.
Im not trying to discourage you from trying. You may need the ask the dev team to roll a new firmware to support this if you know nothing about marlin and Arduino IDE. I dont believe the current firmware is setup to take advantage of a filament sensor.
Also the current “change filament” feature in the Taz6’s lcd menu moves the print head away from the model but leaves the hotend on until you return. Which could be a while depending on how long your gone. I suppose they expected you to change filament right away and continue printing immediately. Not our case use. For our use case with octoprint or a dedicated filament sensor you’d want the hotend to cool down until your return. I have brought up this very concern in the development forums for [new marlin Taz 6 firmware.](https://forum.lulzbot.com/viewtopic.php?f=18&t=6564&start=40url) Please express your desire as well for the feature.
Its definitely a must have feature.
**Author:** ![justinhero](https://avatars.discourse-cdn.com/v4/letter/j/f04885/32.png) [@justinhero](https://forum.lulzbot.com/u/justinhero)\
**Post date:** [November 15, 2017, 2:22pm UTC](https://forum.lulzbot.com/t/taz-6-filament-sentinel-modified-firmware/5008/3 "2017-11-15T14:22:27Z")
Awesome great information nice idea.
> Hey Mulanzo,
> Also the current “change filament” feature in the Taz6’s lcd menu moves the print head away from the model but leaves the hotend on until you return. Which could be a while depending on how long your gone. I suppose they expected you to change filament right away and continue printing immediately. Not our case use. For our use case with octoprint or a dedicated filament [ethnic](https://www.terramart.co.in/) sensor you’d want the hotend to cool down until your return. I have brought up this very concern in the development forums for [new marlin Taz 6 firmware.](https://forum.lulzbot.com/viewtopic.php?f=18&t=6564&start=40url) Please express your desire as well for the feature.
**Post date:** [May 16, 2018, 8:21pm UTC](https://forum.lulzbot.com/t/taz-6-filament-sentinel-modified-firmware/5008/4 "2018-05-16T20:21:31Z")
Hi,
Wondering if anyone has any updates on this or if anyone has tried to implement. As far as I know, Taz 6 now has the required Marlin firmware but wondering if anyone has actually implemented.
**Post date:** [May 16, 2018, 10:50pm UTC](https://forum.lulzbot.com/t/taz-6-filament-sentinel-modified-firmware/5008/5 "2018-05-16T22:50:16Z")
Creating a modified version of the firmware isn’t that difficult. You need to download the Arduino IDE and install it. Install GIT. Use GIT to get a copy of the current firmware. Add the LCD libraries to Arduino IDE (they are included in the GIT download). Edit the files and using the Arduino IDE, generate a new version of the firmware.
I believe the details have been documented in these forums.
