Taz 8 Diagnostic Function
Hello,
Is there a way I can find out why the TAZ 8 printer stops in mid print?
I am running a TAZ 8 at my work and at times I need to print overnight. Sometimes the printer stops mid print, and the display does not show anything out of normal. I can even push “resume” and the print finishes without any further issue. I have tried to print via USB and SD card, but it has happened both ways.
Can anyone point to the right direction?
Is it at a consistent height? Same time with the same file?
Generally look for what’s consistent about the pause.
Usually if there’s a pause that can be resumed from, it’s either an inserted pause command in the gcode, or a filament runout, but with the Taz8, it would require you to complete the filament change before resuming.
Hello Wrathernaut,
Thank you for your reply, it happened twice with the same file, but at different heights. These prints (multiple small parts, about five hours) was made with TPU, and I also thought that it is the filament runout sensor, so I’ve increased the length of the runout distance by 100mm. Still the machine stopped without any indication of the reason for the stoppage. I was able to click resume and the print has finished successfully with an obvious parting line where the stop occurred.
It could be the filament striping detection because the tpu is snagging in the tube and not moving freely it could think the filament is not extruding.
TPU tends to be pretty slick, and sometimes doesn’t cause the wheels in the filament sensor to roll. I haven’t had a Taz 8 to look at, but it looks like there’s tensioning knobs on there that might help.
Thank you Masr1234, I will try to monitor that.
Thank you Wreathernaut, I will play with the tensioner adjustment.
