I was wondering how you insert the bearings inside the holder? I’m having problems trying to get them in.
They just slide in. If it is too tight, you may have to adjust your print. We do have gcode available for TAZ and AO-100 for TAZ parts:
http://download.lulzbot.com/TAZ/3.1/production_parts/printed_parts/gcode/
What kind of printer are you using?
-Jeff
I’m using a printrbot. I’m trying to make parts to build a taz 3. The double bearing holder is the one I have problems with. Could I use two single bearing holders where the double ones are suppose to be?
Yes, but you will have to be careful to make sure the bushings/bearings are well aligned. Otherwise you might see some binding. Depending on what version of the TAZ x-carriage you decide to print, you may need to add some extra holes to mount the bearing holders.
