# Taz6 Extruded Aluminum Frame Non-Standard!?
**URL:** <https://forum.lulzbot.com/t/taz6-extruded-aluminum-frame-non-standard/22968>\
**Category:** Uncategorized\
**Created:** [February 7, 2021, 8:17pm UTC](https://forum.lulzbot.com/t/taz6-extruded-aluminum-frame-non-standard/22968 "2021-02-07T20:17:43Z")\
**Posts on this page:** 3\
**Author:** ![radensb](https://avatars.discourse-cdn.com/v4/letter/r/ba8739/32.png) [@radensb](https://forum.lulzbot.com/u/radensb)\
**Post date:** [February 7, 2021, 8:17pm UTC](https://forum.lulzbot.com/t/taz6-extruded-aluminum-frame-non-standard/22968/1 "2021-02-07T20:17:43Z")
I bought some M3 and M5 [hammer head T-Nuts](https://www.amazon.com/KOOTANS-Thread-Aluminum-Extrusions-Profiles/dp/B07PNV8SWZ/) for an enclosure I am making for the TAZ6. The enclosure uses standard 20mmx20mm extruded aluminum with a 6mm slot (the same stuff I thought the TAZ uses). The T-Nuts I bought (above) worked great in the enclosure frame. I then went to install some in the TAZ6 extruded frame to provide for mounting points with the enclosure - and they don’t fit (!!?!?!). I remeasured the extruded aluminum that the TAZ frame is made of and it is 20mmx20mm with a 5.35mm slot(!?!?!?!). What gives? Did they not use standard materials? I also noticed that they are using a kind of flat T-Nut, which I cannot find.
Does anyone know what’s going on here and where I can find nuts that actually fit this extruded frame??
**Post date:** [February 7, 2021, 8:42pm UTC](https://forum.lulzbot.com/t/taz6-extruded-aluminum-frame-non-standard/22968/2 "2021-02-07T20:42:02Z")
See [T-nuts for TAZ 6 - #3 by mwester](https://forum.lulzbot.com/t/t-nuts-for-taz-6/5697/3)
(Looks like the original product url at 8020 got changed: try this one for nuts that should roll into the TAZ-6 extrusions: [Fastening Methods](https://8020.net/catalog/category/view/id/17/?cat=212&series=19) )
**Author:** ![malcolmthemole](https://avatars.discourse-cdn.com/v4/letter/m/57b2e6/32.png) [@malcolmthemole](https://forum.lulzbot.com/u/malcolmthemole)\
**Post date:** [February 10, 2021, 8:29pm UTC](https://forum.lulzbot.com/t/taz6-extruded-aluminum-frame-non-standard/22968/3 "2021-02-10T20:29:06Z")
I bought several hundred feet of 20x20 V slot recently.
On trying to find a decent price I visited a lot of suppliers.
One thing is for certain… there is no real standard… I found slots from 5.25 to 6.4mm depending on where it was made and which country it was destined for.
As you will agree… it’s not really helpful!
I found a slot I liked and then sought the fasteners to fit it
