# Vibration in y axis even after bed swap
**URL:** <https://forum.lulzbot.com/t/vibration-in-y-axis-even-after-bed-swap/6727>\
**Created:** [May 27, 2019, 2:20am UTC](https://forum.lulzbot.com/t/vibration-in-y-axis-even-after-bed-swap/6727 "2019-05-27T02:20:42Z")\
**Posts on this page:** 4\
**Author:** ![Jardane](https://sea2.discourse-cdn.com/flex020/user_avatar/forum.lulzbot.com/jardane/32/9769_2.png) [@Jardane](https://forum.lulzbot.com/u/Jardane)\
**Post date:** [May 27, 2019, 2:20am UTC](https://forum.lulzbot.com/t/vibration-in-y-axis-even-after-bed-swap/6727/1 "2019-05-27T02:20:42Z")
I have two taz 6 printers and one started having loud Y travel. There was some kind of vibration going on, I could see the Y belt vibrate when it moved. I tried readjusting the bed, adding some lubricant. I even tried replacing the motor with a spare I had.
In tried moving the printer to the floor incase it was the bench but no change.
Then I went for broke and did a bed swap between my two printers the other one worked fine. I easily swapped the two beds and guess what, the vibration was still there with a totally different bed!
What the hell is going on?
**Author:** ![pops](https://avatars.discourse-cdn.com/v4/letter/p/9dc877/32.png) [@pops](https://forum.lulzbot.com/u/pops)\
**Post date:** [May 27, 2019, 12:09pm UTC](https://forum.lulzbot.com/t/vibration-in-y-axis-even-after-bed-swap/6727/2 "2019-05-27T12:09:04Z")
I had what sounds like the same issue in my Y axis. loud noisy vibration. I also was having layer shifting. I replaced belts and bearings to no avail. With the help from Lulzbot support and swapping axis motor driver harnesses, it was proven to be a bad Y axis driver on the Rambo board. Had to replace the board.
**Post date:** [May 27, 2019, 4:52pm UTC](https://forum.lulzbot.com/t/vibration-in-y-axis-even-after-bed-swap/6727/3 "2019-05-27T16:52:45Z")
How much did that cost?
**Post date:** [May 27, 2019, 11:10pm UTC](https://forum.lulzbot.com/t/vibration-in-y-axis-even-after-bed-swap/6727/4 "2019-05-27T23:10:26Z")
$200.00
