# What is the exact aluminum extrusion used?
**URL:** <https://forum.lulzbot.com/t/what-is-the-exact-aluminum-extrusion-used/577>\
**Category:** AO-101 & AO-100\
**Created:** [April 29, 2014, 7:56pm UTC](https://forum.lulzbot.com/t/what-is-the-exact-aluminum-extrusion-used/577 "2014-04-29T19:56:14Z")\
**Posts on this page:** 3\
**Author:** ![MrBlah](https://avatars.discourse-cdn.com/v4/letter/m/a4c791/32.png) [@MrBlah](https://forum.lulzbot.com/u/MrBlah)\
**Post date:** [April 29, 2014, 7:56pm UTC](https://forum.lulzbot.com/t/what-is-the-exact-aluminum-extrusion-used/577/1 "2014-04-29T19:56:14Z")
I know it a t-slot aluminum extrusion. However, I do not know the manufacturer as there are a few of them.
I’ve been googling and coming up with a fair amount of results, but I am not 100% sure on this.
So, does anyone know where I can acquire the identical aluminum extrusion that is used in the LulzBot AO-10X series?
You may ask I need the same one, it’s simply because I would like to change a few dimensions and modify mine, and I want it remain with the same look and same nuts/bolts.
**Post date:** [April 29, 2014, 8:29pm UTC](https://forum.lulzbot.com/t/what-is-the-exact-aluminum-extrusion-used/577/2 "2014-04-29T20:29:29Z")
The AO-10x series used standard square 20mm x 20mm T slot extrusions sourced from Mitsumi. For example, these ones are identical in dimension to the ones used for the AO-10x series. [http://www.ebay.com/itm/80-20-Inc-Metric-20mm-x-20mm-T-Slot-Aluminum-20-Series-20-2020-x-420mm-Black-/331156872526?pt=LH\_DefaultDomain\_0&hash=item4d1a7cdd4e](http://www.ebay.com/itm/80-20-Inc-Metric-20mm-x-20mm-T-Slot-Aluminum-20-Series-20-2020-x-420mm-Black-/331156872526?pt=LH_DefaultDomain_0&hash=item4d1a7cdd4e)
Any 20mm x 20mm square extrusion with a single bolt channel per side will be compatable with the existing AO-10x parts. Almost all of the T-slot extrusions for sale at 20mm x 20mm were made with the same extrusion dies. The T-nuts are standard as there are only so many T-nut sizes you can get into a 20mm extrusion. The extrusions they sell for the TAZ here which are longer are also the same 20mm x 20mm dimensions.
Avoid the specialty extrusions (v groove, etc) unless you account for the additional width.
I used to get my longer pieces from makerstoolworks, but they seem to have stopped carrying T-slot extrusions recently.
**Author:** ![waleeedijaz](https://avatars.discourse-cdn.com/v4/letter/w/c0e974/32.png) [@waleeedijaz](https://forum.lulzbot.com/u/waleeedijaz)\
**Post date:** [March 7, 2016, 9:22am UTC](https://forum.lulzbot.com/t/what-is-the-exact-aluminum-extrusion-used/577/3 "2016-03-07T09:22:38Z")
