what are the settings for wood filament using quick print and lulzbot mini or is it not possible
new to this but am all in je
You will need to download the profile you’d like to use from here: https://www.lulzbot.com/support/mini-cura-profiles and import it into Cura.
Download this profile:
http://download.lulzbot.com/Mini/1.0/software/cura/profiles/laywood_default_mini.ini
In Cura go to: Expert > Switch to Full Settings
Then select: File > Open Profile > Select the file you downloaded earlier
Load your model, and print!
