# X-Level
**URL:** <https://forum.lulzbot.com/t/x-level/6192>\
**Category:** LulzBot Mini\
**Created:** [September 19, 2018, 3:51am UTC](https://forum.lulzbot.com/t/x-level/6192 "2018-09-19T03:51:12Z")\
**Posts on this page:** 4\
**Author:** ![mhr\_lulzbot](https://avatars.discourse-cdn.com/v4/letter/m/dc4da7/32.png) [@mhr\_lulzbot](https://forum.lulzbot.com/u/mhr_lulzbot)\
**Post date:** [September 19, 2018, 3:51am UTC](https://forum.lulzbot.com/t/x-level/6192/1 "2018-09-19T03:51:12Z")
When X-Level-ing, the nozzle is not supposed to touch the back right washer: Correct?
**Author:** ![NBradshaw](https://sea2.discourse-cdn.com/flex020/user_avatar/forum.lulzbot.com/nbradshaw/32/104_2.png) [@NBradshaw](https://forum.lulzbot.com/u/NBradshaw)\
**Post date:** [September 19, 2018, 2:37pm UTC](https://forum.lulzbot.com/t/x-level/6192/2 "2018-09-19T14:37:03Z")
I’m not sure if you are referring to leveling the x-axis on the Mini 2, or if you are using another printer, but on the Mini 2, the level x-axis option should not hit the back right washer. It will get a bit close, but it should not make contact.
**Author:** ![mhristau](https://sea2.discourse-cdn.com/flex020/user_avatar/forum.lulzbot.com/mhristau/32/9696_2.png) [@mhristau](https://forum.lulzbot.com/u/mhristau)\
**Post date:** [September 19, 2018, 2:57pm UTC](https://forum.lulzbot.com/t/x-level/6192/3 "2018-09-19T14:57:30Z")
OK Thanks
Yes, Mini2
I ask because I’ve been printing parts with the same profile / same filament but having to change z-height to get a good first layer. Varies from 1.09-1.11. Not sure why.
**Author:** ![monsteroyd](https://avatars.discourse-cdn.com/v4/letter/m/43a26b/32.png) [@monsteroyd](https://forum.lulzbot.com/u/monsteroyd)\
**Post date:** [October 1, 2018, 8:39pm UTC](https://forum.lulzbot.com/t/x-level/6192/4 "2018-10-01T20:39:18Z")
Is this the Z-offset? or something else that you are fiddling with? On my Mini2 the Z-offset is the distance in mm from the top of the washer at the corner to the PEI/glass bed.
Thanks
Monty
