TAZ dual extruder mod files
1013
Re: TAZ dual extruder mod files
Post by 1013 » Sat Jun 22, 2013 1:06 pm
scale by 25.4 they were saved as metric....I think.
Gemini64
Post by Gemini64 » Sat Jun 22, 2013 1:07 pm
Scale should be 100% AFAIK. Don't know why they import tiny for you in Slic3r, here's how the large and small gear imported in Slic3r looks like for me.
Please note that I have an AO-100 so my build platform is smaller than the TAZ (mine is 200x190mm).
benfarmer
Post by benfarmer » Sat Jun 22, 2013 1:54 pm
Here are the outside dimensions according to slicer when I scale them up 25.4 times:
TAZ_DUAL_EXTRUDE_adjustment_block_1013 - 116x99.6x27
JKGWT1013-v3_Motor_Moved_Extruder - 109.83x59x28
TAZ_DUAL_ExtruderMount_1013 - 115x118.82x102.06
Does that look about right? I'll post comments on the Thingiverse object after I print them.
benfarmer
Post by benfarmer » Sat Jun 22, 2013 2:26 pm
Here is the list of printed parts needed, as I understand it:
From Lulzbot
Latch - 2x (http://download.lulzbot.com/TAZ/hardwar ... ch-2.0.stl)
Idler and Washer - 2x (http://download.lulzbot.com/TAZ/hardwar ... _idler.stl)
Herringbone Large - 2x (http://download.lulzbot.com/TAZ/hardwar ... ar-1.0.stl)
Herringbone Small - 2x (http://download.lulzbot.com/TAZ/hardwar ... ar-1.0.stl)
From User 1013
Motor Moved Extruder - 2x (JKGWT1013-v3_Motor_Moved_Extruder.stl - http://www.thingiverse.com/thing:106147)
Adjustment Block - 1x (TAZ_DUAL_EXTRUDE_adjustment_block_1013.stl - http://www.thingiverse.com/thing:106147)
Extruder Mount - 1x (TAZ_DUAL_ExtruderMount_1013.stl - http://www.thingiverse.com/thing:106147)
Next up is to get the exact list of parts/hardware needed.
benfarmer
Post by benfarmer » Tue Jun 25, 2013 4:53 am
Once the Motor Moved Extruder file is updated (it's printing in mid-air in two places; see the pictures on thingiverse) I will have all the printed parts done. I'm getting together the list of hardware needed now. Looking forward to building it!
1013
Post by 1013 » Tue Jun 25, 2013 4:42 pm
benfarmer wrote:Once the Motor Moved Extruder file is updated (it's printing in mid-air in two places; see the pictures on thingiverse) I will have all the printed parts done. I'm getting together the list of hardware needed now. Looking forward to building it!
Just added a support version to thingiverse, and will updated the OP soon.
Thanks to lulzbot for helping with adding the support. I just copied and pasted the support from their file.
benfarmer
Post by benfarmer » Wed Jun 26, 2013 5:26 am
Thanks! I'll print it out tonight and post some pictures.
Haas08
Post by Haas08 » Mon Dec 02, 2013 7:59 pm
Hi All,
First post, Just paid for my TAZ, looking forward to it arriving. FedEx decided to price the cartage via "airplane" to Oz and not quantum tele-portation via the Moon and a parallel dimension, (thank Rachael, you help me out heaps!). First transport quote had me thinking Mr Obama was going to hand deliver it using Air-Force One and a motorcade...
Perhaps a silly question, but would smaller Nema motors keep the weight down on these dual head mods, or is that already the smallest one that will get the job done?
Looking forward to tinkering with me TAZ.
Andrew
piercet
Contact:
Post by piercet » Mon Dec 02, 2013 8:22 pm
Ouch, yeah those quantum teleportation charges to paralell dimensions can be rough. that's why I only ship things via quantum teleportation to perpendicular universes.
Regarding smaller Nema motors, that is definitly something that is at least being looked at. Check out this thread here for some information regarding efforts to make a smaller, lighter extruder http://forum.lulzbot.com/viewtopic.php? ... 9&start=10 Specifically they are going to look at a 20mm NEMA motor instead of the current one as a possibility. My own minor contribution to that extruder design piece, I also made a belt drive variant which should be slightly lighter in theory anyways. Assuming it works and doesn't explode and all.
I think the general plan is once the flexystruder design is tested and tweaked to perfection, they will try it in a dual extruder array and see what happens.
I'd also like to see a "2 filliaments into one budaschnozzle" modification, but the timing and retract needed for that would be scary.
Haas08
Post by Haas08 » Mon Dec 02, 2013 10:33 pm
Ah should have ticked 'perpendicular universe' option, I'll remember for next time!
Found this re the Nema 11, he is driving 1.75 filament though. The nema 11 spec looks like they weight half what the 17's do.
http://www.thingiverse.com/thing:7975/#comments
i'm thinking this (dual extruder) will be an early mod for me, as the parts i need to make have a fair amount of overhang, so I'm thinking ahead a bit.
Andrew
