Filament Guide Tube Restrainer Clip
filipto
Post by filipto » Tue Mar 03, 2015 8:40 am
This is a restrainer clip for TAZ (3) for mounting on the tool head. It holds the nylon tube in place to reduce strain on filament (especially cheaper PLA filaments that like to snap during printing) while the print head is moving..
You do have to drill a hole and install a heat-set insert for it to securely installed on the print head. I used M2.5 insert and 16 mm M2.5 screw on mine.
FilamentGuideTubeRestrainer.STL
(131.72 KiB) Downloaded 128 times
TAZ Filament Guide Tube Restrainer Clip
nopick
Re: Filament Guide Tube Restrainer Clip
Post by nopick » Tue Mar 03, 2015 8:49 am
Nice mod. I have some standard grade Matterhackers PLA that likes to snap. This will also provide a flat elevated surface to measure from when checking for proper extrusion calibration.
jimboslice
Post by jimboslice » Wed Oct 24, 2018 8:10 am
Is it possible that you still have this mod installed and could attach a photo of where you drilled the hole, my filament keeps snapping and I need a way to fix a guide tube to my toolhead, but dont want to go drilling around without knowing what im doing. Thanks!
