Bed Temp Change after uploading firmware on Taz5
Wolfie
Post by Wolfie » Thu Mar 12, 2015 2:29 am
In installed the Flexi-Dualie tonight. And per instructions I downloaded a copy of the firmware. Ever since then, the bed is reading about a degree off of its set temp. For example if I set it to 90 in S3D, it sits there forever waiting on the bed to warm up reading 89.3
I am hoping there is an easy fix for this.
Frankly, I am surprised that the firmware in the Taz 5 wasn't already set up for the dual extruder.
LulzBot Taz 5
dutchhome
Re: Bed Temp Change after uploading firmware on Taz5
Post by dutchhome » Thu Mar 12, 2015 8:57 am
Maybe wait for someone more experienced than myself to answer, but I believe you may need to tune your pid settings in marlin for your heated bed.
PID tuning refers to a proportional-integral-derivative control algorithm used in some repraps for hot ends and heated beds.
PID needs to have a [Proportional (P) constant Kp], [integral (I) constant Ki] and [derivative (D) constant Kd] value defined to control the nozzle temperature. If the temperature ramps up quickly and slows as it approaches the target temperature, or if it swings by a few degrees either side of the target temperature, then the values are incorrect.
Here is the AO article:
https://www.lulzbot.com/support/fine-tu ... d-settings
For more detailed information about it:
http://reprap.org/wiki/PID_Tuning
Lulzbot TAZ 4.1
Upgraded to Hexagon Extruder
Converted old extruder to Flexystruder 1.1
Wolfie
Post by Wolfie » Fri Mar 13, 2015 7:12 pm
Well, tried both:
M303 E-1 S60
and
M303 E-1 S60 C8
Bed refuses to heat up and sits there reading at 26c.
Sigh. I just realized NOTHING is heating :(
Cripes, do I have to redownload the firmware when I swich back to the single extruder hex head? Geez, thats fuzzy right there.
LulzBot Taz 5
Wolfie
Post by Wolfie » Fri Mar 13, 2015 7:27 pm
Man, thats a fail. Yea, I had to re-flash the firmware when switching back to the single extruder. Now its heating up and runnig the test.
LulzBot Taz 5
dutchhome
Post by dutchhome » Sat Mar 14, 2015 5:59 am
Aleph Objects has done such a good job with the TAZ that it is easy to think that the firmware going forward would just work with all of their previous extruders. I certainly had that stuck in my head. In the end they are still using Marlin and are at the mercy of how it works. I started going through the code to fully understand its limits, but it is all written in C so a bit hard to follow (ok, technically C++, but rather than using encapsulation and inheritance they use #ifdef's everywhere. Maybe makes sense considering the limits of the platform, but makes it harder to follow than if they used a true object oriented design).
In the end I think we should plan to swap the firmware any time we switch number of extruders or when switching between Budaschnozzle and Hexagon hot ends.
Lulzbot TAZ 4.1
Wolfie
Post by Wolfie » Sat Mar 14, 2015 4:23 pm
That was my presumption as well. I expected to be able to drop the head in place, attach the wire harness and get on with it. I was surprised at the fact it wasn't recognized right away since Taz5 is their newest build.
I was also dumbfounded that it simply shut down when I returned to a single extruder. Its really completely counter-intuitive. Ok, maybe get it that 2 isn't the default. But the current build should be smart enough to figure out that extruder 2 isn't there and revert to single extruder function. Seems pretty simple logic if you ask me.
I returned to the hex head as the flexi-dualie was producing sub-par results. The primary extruder on it seemed ok but wasn't quite as good as the hex (maybe I got spoiled). And the secondary head was, well, totally unacceptable and I am still debating on its actual functional status.
I shot an email to support to see what they say.
Take a look at the image.
Fexi-Dualie Bent Plate?
If you look, the sub-plate on which the two extruders are mounted is really bowed badly. This is causing the flexistruder to sit at an oblique angle to the bed and to the other extruder. I think the plate is warped to be honest but not having ever seen another one I have no other point of reference to base that assumption on other than my gut telling me it looks wrong. I screwed the height adjustment screw well down as if you look closely the plate is not even touching the screw head.
Maybe its normal. Maybe its just the new filament I bought and am feeding the flexistruder with (ABS white from MatterHackers). I am finishing a print job making some LED brackets to put strip lighting on the TAZ frame. Once thats done I am going to feed the white into the HEX and do some test prints to see if it stacks up or the filament is crap.
Classic error. Changing two things at once (head and new filament). Can't tell which is at fault for poor results. So, I am returning to a known good condition (black ABS from MakerGeeks and my Hex head). Then change to the new filament and print the same things and see if there is a quality difference. If there is, its the filament, if there isn't then its the flexistruder.
Honestly, I think I am getting pretty solid results with the Hex and Taz 5. I have only had it what, a bit over 2 weeks now?
Hex Results
Honestly, I had hopes that the same or at least remotely similar results would happen with the Flexi-Dualie. Not so much.
Fexi-Dualie results
LulzBot Taz 5
dutchhome
Post by dutchhome » Sat Mar 14, 2015 5:33 pm
Did you run through the calibration on the flexy dually (the thing that prints squares with each extruder inside each other)? I haven't tried printing the objects you did, but it looks like the two extruders are not calibrated to each other.
By the way, I would not expect as good of results with the current flexy dually. First of all, the hexagon hot end has excellent results. It rocks. Second, the hexagon uses a 3.5mm nozzle and the flexy dually uses .5mm nozzles. Even once it is properly calibrated you will find that you won't get quite the same resolution. It looks like they are working on a hexagon-based flexy dually (and standard dual extruder and single flexystruder too), but it isn't quite ready yet.
Regarding any warping on the extruder, my guess is that it shouldn't affect anything. When you calibrate the flexy dually, it takes a bit of playing around to get the two extruders Z level in sync. When doing the calibration, you spin the thumb screw and the extruder body must flex.
Lulzbot TAZ 4.1
kmanley57
Post by kmanley57 » Sun Mar 15, 2015 8:58 am
If you re-flash your firmware you have to do the PID calibrations because the code has default values it used, thus is not actually tuned to your bed and extruder.
As for the dual to single change, the dual firmware is looking for a thermistor reading for each extruder and if you have the single extruder on there it will give a 'min/max temp' error for the missing thermistor and not heat up anything as you found out.
I fool the dual extruder firmware out by attaching just another thermistor on the second extruder cable, and thus it gets a reading it is looking for on the second extruder thermistor that is not really there for the single head extruder body.
This way I do not have to change firmware when going from one to two heads and back on the TAZ.
dutchhome
Post by dutchhome » Sun Mar 15, 2015 9:32 am
Thats a great idea. How are you connecting the thermistor? Did you put it in its own four pin connector?
Lulzbot TAZ 4.1
Wolfie
Post by Wolfie » Sun Mar 15, 2015 10:54 am
dutchhome wrote:Did you run through the calibration on the flexy dually (the thing that prints squares with each extruder inside each other)? I haven't tried printing the objects you did, but it looks like the two extruders are not calibrated to each other.
Alignment
Yes, I ran through the alignment process. I did the square test. I plugged in values to slicr. I got it to print the squares all fine and dandy. Centered as best as you can mesaure it on the print plate.
Then I printed the large cone via Simplify3D. I used the same figures as from slicr. And it came out looking like that, offset by a considerable amount. So I shrank the cone down (to use less materials) and proceeded to re-align it. In virtually every print, the white (flexi) would print ever so slightly larger than the orange (budda). As you can see I downloaded a ring test object and started using it (even less material).
Thinking I got it aligned I printed the dice. The white dots looked like they were in the right position. I tried playing with the settings to get results like I did with the hex. I never did get it close. I gave up started the octopus and went to bed. That was my surprise for the morning. A God awful mess. After work, I played again for another couple hours and finally gave up and put the hex back on.
That was the realization that the firmware needs changing...and the bed calibration, etc.
Nozzles
My Flexi-Dualie came with one .35mm and one .50mm nozzle on the buddas. The .35 is on the primary and the .50 is on the flexistruder.
Warping
Ya, I realize its got to flex to adjust the Z which I agree is a pita to get right. But also read what I said. Its bent like that with NO PRESSURE from the Z adjustment screw. Look close, I backed it all the way down, thee is a air gap there. Its bowed like that with no contact with the screw.
And yes, before you ask, I did do extruder calibrations too. I even made my own helper web page to make it easier.
http://www.wolfiesden.com/TAZ/ExtruderCal.asp
Yea, the thermister idea is a good one but only bandaids the problem of stupid software. It should be able to comprehend that its only got a single extruder on it and revert to using only single extruder settings. If its not that smart, then a setting in the LCD should be easy enough to set number of extruders (1->2).
I have been programming in BASIC for decades. Yes, plural. Cobol and Fortran are also in my tooklit as are Pascal and Fourth. And daily in Javascript and not as often Java. I only briefly worked in C++ but in the last couple years I have had to bone up on C# and .NET as we are converting all my ASP eCommerce and CMS code to C# (and re-writing it for new trends/technologies/standards). Javascript and C# are really similar syntactially to C++ which is what I think Marlin is written in. I might have to take a look at the code when I have time to pursue it. I would have to see how much room there is in the EPROM and flash ROM for new features or additional code, not up on the specs on this chip as I only have an Arduino Uno, much smaller memory I think than whats in the Taz.
I would also like to add menu controls for home individual axis as well as seek the corners for bed leveling to the menu functions on the TAZ. And to be able to control all 3 axis as well as extruder. I would also like to add multiple Esteps storage and recall for different filaments. Right now its got 1 and I am using Gcode presets in FFF files in S3D. I would also like multiple profiles which would store/retrieve different banks of settings with the M92 code. When changing heads, I could switch banks using the LCD. Whether thats possible with the memory available, I don't know yet.
LulzBot Taz 5
