First dual extrusion print from a Cyclops hot end and BondTech QR extruders
mhackney
Contact:
Re: First dual extrusion print from a Cyclops hot end and BondTech QR extruders
Post by mhackney » Mon Jan 04, 2016 3:55 pm
config.json.txt
(14.28 KiB) Downloaded 140 times
Remove the .txt extension. The .json file can be imported into the repetier online configuration tool (which you should learn how to use) so you can tweak things for your setup.
Sublime Layers - my blog on Musings and Experiments in 3D Printing Technology and Art
Start here:
A Strategy for Obtaining Great Prints
Strategies for Resolving Print Artifacts
The Eclectic Angler
chriscalandro
Post by chriscalandro » Mon Jan 04, 2016 3:57 pm
Excellent. I know the config utility well. Just figured why search through my current firmware for numbers if someone already did it...
chriscalandro
Post by chriscalandro » Mon Jan 04, 2016 4:03 pm
Are you actually using Jam detection?
Also, how good are these PID settings? I'm using the same sensors.
mhackney
Contact:
Post by mhackney » Mon Jan 04, 2016 4:08 pm
No, is that configured in this file?
Start here:
The Eclectic Angler
chriscalandro
Post by chriscalandro » Mon Jan 04, 2016 4:14 pm
There are values entered and I don't see a tic to enable it, which probably means anything other than 0 means it's active.
PID settings also look very wrong for the heated bed (assuming you are using the stock heater/glass.
This is from the Marlin firmware - and is pretty good
Code: Select all
#ifdef PIDTEMPBED
//24V 360W silicone heater from NPH on 3mm borosilicate (TAZ 2.2+)
    #define  DEFAULT_bedKp 162
    #define  DEFAULT_bedKi 17
    #define  DEFAULT_bedKd 378
chriscalandro
Post by chriscalandro » Mon Jan 04, 2016 4:17 pm
Sorry! False alarm! It gets disabled in the extruder settings.
mhackney
Contact:
Post by mhackney » Mon Jan 04, 2016 4:20 pm
Great. I can't imagine the QRs jamming! I've had more success with these extruders (now on 4 of my printers and working to print mounts for the remaining 2) than any other. Not a single jam or even close yet. And the Cyclops is a difficult hot end to push filament through.
Start here:
The Eclectic Angler
chriscalandro
Post by chriscalandro » Mon Jan 04, 2016 5:18 pm
I'm going for basically the same setup as you for the taz. Minus z probe and I'm buying the hardware kit for the extruders and I'll print my own plastic bits.
What I need is a reliable dual hot end. My research has shown the bondtech extruders are the best, most reliable design.
Did you see my note about your pid settings?
chriscalandro
Post by chriscalandro » Mon Jan 04, 2016 5:19 pm
mhackney
Contact:
Post by mhackney » Mon Jan 04, 2016 5:56 pm
Hmm. I am using the stock heater. I do have a sheet of PEI. I did not retune it but the bed seems stable enough.
Start here:
The Eclectic Angler
